A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 11th July 2013, 10:17 PM   #481
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
If this is usefull for all, maybe someone from Netherland can post a summary of that test in english.
It is useful I find. Easiest would be to use google translate. I might be able to translate it but it will take a while since I'm pretty busy the next couple of weeks. The essence of the article though is this: All the transformers in that test "suffice". That is to say that none of them are bad. The reviewer found the Cinemag to be the best of the three under test all things considered. He was dissapointed that he was not able to test it head to head in a listening session with the Sowter 3575 because the he did not have the Sowters anymore. The Magnequest sounded more powerful but the "depth of the soundstage" and the " better seperation" made the Cinemag top of the pops subjectively for the person doing the listening.
Also he prefers the output transformers over perhaps any capacitor in the DDDAC1794.
Cinemag CMLI 15/15B is good for the price.
He found the Cinemag best of the three. But even more so taking into consideration the price. Which gives it a slightly different meaning.
If you can see the speaker cone move...it's not hifi.
Old 13th July 2013, 11:17 AM   #482
spacejay is offline spacejay  England
Originally Posted by qusp View Post
wow, thats the first time i've ever heard someone deliberately increasing the likelihood of RFI, EMI, lowering CMRR, raising distortion (well this one seems quite popular). its basic housekeeping stuff, not pedantic, but hey whatever makes you happy.
here is what the designer wrote about it -
if you put two wires in close proximity then they talk to each other and you create a capacitor that means that v high frequency information bleeds between then. So if L and R channel signal then you lose seperation, if + and - of the same leg then you lose some of the v high frequency information of the music as the cable is acting as a filter. If you then twist the cable you put the cable in even closer proximity which increases capacitance again and also introduces a small inductive element into the load.
I see no logic in their statement as all they can be referring to is stray RF which it will remove along with some of the musical content.
Try both ways and do what your ears tell you.
well to be honest i can't be arsed - he doesn't on his amps for the above reasons. have you considered that there may be an upside?
Old 13th July 2013, 11:43 AM   #483
xslavic is offline xslavic  Moldova
so you're saying that we should only twist one channel and Ground ?
and of course it helps twisting the power cables
-but can we use coaxial for internal wiring ? i think ou can twist them on a stick until some effect is noticed -comes with over 61pf capacitance though between ground and middle cable
Old 13th July 2013, 03:36 PM   #484
Supersurfer is offline Supersurfer  Netherlands
Coaxial is bad for sound as Spacejay says. But also the plastic isolation (dielectric) has audible effect. Interesting reading on this topic: " the supercables cookbook" by Allen Wright.
It is also true that open cabling introduces a loop in the system that can pick up electromagnitic fields.
So it is important to use both coaxial/twisted and seperated cabling in your system at the right spot. I use speaker cabling with the two wires seperated 30cm from each other. This is much better than twisted (what I also tested) but in high frequency designs, such as USB cables, twisted is better for RFI rejection ( but I found it not suitable to use coaxial here).
Old 13th July 2013, 05:14 PM   #485
qusp is offline qusp  Australia
qusp's Avatar
no, there is no upside. who said anything about twisting everything together? you havent twisted anything at all, you have everything just flopping around, the ground wires are not even close to the signal wire , let alone twisted. each signal should be twisted with its ground, or if balanced, it should be twisted with its opposite polarity. i'm not saying all the wires should be twisted into a bunch.
the bold bit is, i'm afraid, nonsensical … +/-, or +/G are 2 parts of the same signal, the signal is induced between the 2 and in solid state electronics for example current is more correctly described as flowing from ground, not to it. none of the signals are VHF and if they were, it would be even more important to have ground and signal, or + and - in close proximity. the signal doesnt travel up the signal wire and then dribble out into ground
xslavic: coax can be useful for single ended low level signals, but for balanced twisted pair is superior.
I cannot think of a single reason to separate a signal and its return leg, not least by 30cm, this makes for huge inductance and makes it more likely to pick up and transmit noise. speaker cables are driven reasonably hard, so its maybe not as noticeable, I dont know what was going on in your system, but there is no good reason to make loop area larger.
there seems to be a fair few odd assertions going on here … this is all pretty basic signal integrity stuff
Old 13th July 2013, 06:04 PM   #486
AudioH is offline AudioH  United Kingdom
Smile I/V Resistor Trials
Originally Posted by Supersurfer View Post
Hi Howard,
Please keep us posted on your findings.
So after this and the other posts on the differing I/V resistor types I invested in 4 off Audio Note tantalums and 4 off Amtrans AMRG carbon film , all 68 Ohm as I have a two board setup.
Compared to the Dales both are a significant improvement. Both provide more clarity to the music and by that I mean the ability to hear more detail, the removal of another veiling layer. Particularly noted is the better differentiation between instruments and the space around them. Also to note is the increased dynamics and the ability to respond to the rate of dynamic increases. One surprising affect clearly heard though was the better rhythmic interplay between musicians. (This reminds me of the Naim PRAT argument !).
Take for example the Art Blakey and the Jazz Messengers track, "A night In Tunisia". Both of the above provided much better interplay between the players. When all are playing together the Dales were somewhat muddled and differentiating them was more difficult. With both the ANs and Amtrans each player clearly had their own space in the acoustic and the ability to hear the interaction between them much increased.
Both also took off a slight hard edge to the Dales presentation, the Amtrans providing a much 'smoother' , somewhat 'laid back' presentation compared to the ANs but both far better than the Dales. Th dynamic rate changes were some what slower than the ANs here.
My output is balanced with no decoupling caps., wired with Jupiter silver wire in cotton, so is a very direct output, perhaps helping to hear the above more than the single ended connection ?
Hope this helps .
Howard
Old 17th July 2013, 06:21 PM   #487
Hi Howard,
Thanks for your analysis! You are right that the balanced setup is more reveiling in this area because the caps are out. I also use solid silver wiring with cotton (C37 laquered) this is the best!
I will try the tants after my summer holiday. The sound balance you describe compairs with my experience in tube amps. This does not mean the Dale are not good, they only change the sound balance.
The choice depends on the balance of your system (and maybe your ears )
Old 20th July 2013, 09:51 AM   #488
Default AudioH DDDAC MKII
MKII now finished with improved graphics display, so I can read it from a distance.
I designed a dedicated board for the graphics LCD to take the Teensy+ processor and associated parts. This was my first pcb so really pleased how it turned out.
DDDAC parts mounted on an acrylic base isolated from the main case by sorbothane isolators for vibration reduction.
Howard
Old 21st July 2013, 07:53 AM   #489
Undarra is offline Undarra  United Kingdom
Hi Howard
That looks great. I've just finished building mine and had a first listen yesterday, sounds fantastic to me. Do you mind telling me where you got your enclosure from, it looks like it would match my croft pre and power amps perfectly.
Thanks, Si
Old 21st July 2013, 07:42 PM   #490
Originally Posted by Undarra View Post
Hi Howard
Thanks, Si
It's a Maplin 2u 19inch rack unit . I milled out the LCD panel section.
Best regards
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
