A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 24th June 2013, 08:23 PM   #421
Supersurfer is offline Supersurfer  Netherlands
Hi Howard,
I have three resistor types that have sticked to my (tube) designs since the last 20 years. After dropping metal film (all types), holco, caddock, mills and such.
The ones that sticked and can be used for the dac are:
-allen bradley and even better; riken carbon
-tantalum, shinkoh or audio note ( second choice).
Third type is a wirewound power resistor not suited for the dac.
The carbon is best in series with signal; grid stopper and attenuator.
The tantalum is best connected to ground; grid leakage, attenuator to ground.
All resistors have their strengths and must be used in the right position.
Also each type has it's own sound, so the sound balance will change for better or worse and that has nothing to do with price or quality of the resistors.
Higher wattage is usually better because it is more temperature stable and has less resonance due to the size.
For this application I would use the tantalum. I will try this in the future.
Please keep us posted on your findings.
Old 24th June 2013, 08:42 PM   #422
xslavic is offline xslavic  Moldova
why so? 4 resistors cost more,and the ground cant be so clean
anyway you take reference right at the opamp from pin6 to gnd ith Rfeedback
can you tell me the reasoning for it. ? thanks
Old 25th June 2013, 05:46 AM   #423
AudioH is offline AudioH  United Kingdom
Sorry dont understand this, there is no opamp in the design.
Old 25th June 2013, 05:49 AM   #424
Originally Posted by Supersurfer View Post
Hi Howard,
Hi Supersurfer
Will buy some of the above recommendations and give them a try
Old 25th June 2013, 07:04 AM   #425
IanS1 is offline IanS1  United Kingdom
Anyone tried these as a replacement for the Riken Carbon?
Amtrans AMGR carbon film Resistors,0.75 watt and 2 watt
Old 25th June 2013, 09:45 AM   #426
Don't look too expensive so will to shopping list
Howard
Old 25th June 2013, 02:09 PM   #427
spacejay is offline spacejay  England
is dd on holiday at the moment? i emailed him a question and ordered a kit from him last week and have heard nothing back from him since.
Old 25th June 2013, 03:16 PM   #428
Almeg69 is offline Almeg69  United Kingdom
Doede is travelling around with work at the moment, replies will be as he gets a chance :-)
Thanks, Alex.
Old 26th June 2013, 02:16 AM   #429
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
Looking forward to reading about the comparos IanS1.
As currently just running a single board and with funds for hifi being quite limited for the foreseeable future, bit undecided of which direction to go to maximize the performance of the kit.
Cheers!
Old 27th June 2013, 05:31 PM   #430
dookie182 is offline dookie182  France
x1
I'm also looking forward to the comparaison...
all the best
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
