A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input) - Page 41 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th June 2013, 08:30 AM   #401
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I join the group of the DDDAC builders !!
Welcome to the growing club of builders!!!
planet10 needs your help:
Let's help Ruth and Dave
Old 18th June 2013, 06:22 PM   #402
Hi there, I am new on DIYaudio.
I am also building the new DDDAc1794, with eight decks. Stil now two to go, and I have to look for the LM7805. Maybe next week I can finish my project. A lot of 24/192 music to play...!
Altjo
Old 18th June 2013, 06:31 PM   #403
Originally Posted by bravi View Post
Hi Supersurfer,
Do you by any chance have spare transformers in your bin to try an experiment? If you have some with a similar voltage to the one you have powering the shunt regs, try paralleling to them so that you have at least 2 or 3 times the VA and see if you hear any difference.
The suggestion is made since a choke input supply designed for critical current flow should not have any difference just by increasing the current rating of the power transformer ( By the way I was running it at only 35% capacity, well below the possible utilisation for a choke loaded supply). But it seems that even though the sec voltage is the same and the rectified voltages are the same, the improvement in sound quality is quite obvious.
Cheers!
Hi Bravi,
I have used a toriodal 300va transformer, with a variac to adjust to the right voltage, just before my transformers arrieved. And, yes there is a difference.
I also have the experience that there is a big difference in sound using other rectifier tubes (in my amps and another dac with tube outputs) or furutech power supply shuko connectors for that matter.
So it is all a matter of combining the right items to create the sound balance you want.
The sound balance of your dac should fit the balance of your complete set, I often need to change some component somewhere else in my setup: when I upgrade a component like the dac, I end up changing the tube settings of my amp to correct the balance.
Old 18th June 2013, 08:07 PM   #404
another one who has just bought the kit, looking forward to it arriving. unlike most of you guys i don't know much about the technical stuff but i can solder and have enjoyed making phono stages, headphone amps, power supplies and some speakers.
have any of you experimented with the capacitors?
Old 18th June 2013, 08:17 PM   #405
Check my post #259
Old 21st June 2013, 07:30 PM   #406
IanS1 is offline IanS1  United Kingdom
I will be finishing assembly of a single DAC board with Tentlabs regulators this weekend. Looking forward to trying this one out against my 4 DAC board version.
Old 21st June 2013, 07:44 PM   #407
That is awesome. Way way better to compare them like that.....rather than first listen...then add shunt regs and listen again.
Old 21st June 2013, 07:52 PM   #408
We also have a standard single board version so we can do AB tests.
Old 21st June 2013, 08:05 PM   #409
Hi Ian,
That looks very good! For best performance you need to remove the 47uf capacitors downstream of the regulators: c18, c32 and c27 (left channel example).
If you keep these , the shunt regulators will feed the capacitors and that will slow down (dampen) the regulation.
I am very curious on your findings how this compaires to the standard 4 board set; please keep us posted!
Old 21st June 2013, 08:19 PM   #410
Yes Stefan, we will remove the caps once we have got a feel for the sound. Hopefully we will hear improvements once the caps are removed.
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
Copyright 1999-2017 diyAudio
