A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 25th November 2012, 11:15 AM   #11
studiostevus is offline studiostevus  Netherlands
Originally Posted by clivem View Post
Yes, but that's 96k at 8x OS. ie. 768kHz.
Correct, it should do 192 in nos mode. I am contemplating on designing a pcm1704 dac, but i am not sure if it's worth it. I generally find there is limited hi-def material around...
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 25th November 2012, 11:39 AM   #12
Jackal29a is offline Jackal29a  Spain
Wouldn't it even do DXD in NOS mode?
Old 25th November 2012, 11:41 AM   #13
clivem is offline clivem  United Kingdom
There are several 192k/24 bit NOS designs built around the PCM1704 out there. Although the data-sheet states a max of 96k @ 8x OS, I believe Kingwa (Audio-GD) is running 192k @ 8x OS from his DSP to the 1704, which would imply that the chip is actually capable of a 1.536MHz word clock.
I have a little 96/24 material. Based on my own experiences, I still prefer that material run through 16 and 18 bit R2R DAC's, even with the loss of resolution.
Old 25th November 2012, 02:31 PM   #14
dddac is offline dddac  Germany
DDDAC Audio
Very valid Point. I simply overlooked that in the early days. High price and output arguments played a role as well of course, as well minus power supply. After that I hold on to the PCM1794. Might have had still oversampling specs in mind then. Anyway, 96kHz was not the only showstopper. Does not change a thing on the fact the PCM1794 in NOS is performing great
Nevertheless it is tempting to try a pair of 1704 though
www.dddac.com
Happy listening and building
Old 25th November 2012, 02:38 PM   #15
DDDAC Audio
DXD must be supported by the USB Receiver. The WaveIO does not Support that according to specs (max 192kHz)
You would expect that the DAC as such would support this, as the 8x oversampling is omitted, but I have not been able to test this...
I see the next experiments coming
www.dddac.com
Old 25th November 2012, 02:42 PM   #16
DDDAC Audio
well have a look at my 3TB drive than
I believe there is more than enough out there and of excellent quality.
But that is my personal opinion of course
www.dddac.com
Old 25th November 2012, 04:26 PM   #17
The WaveIO does not go over 192KHz but at 39 the Amanero board does (PCM up to 384KHz and also DSD):
http://www.diyaudio.com/forums/vendo...converter.html
Old 26th November 2012, 02:04 PM   #18
Deode,
I've been pondering. I'm biased, a fan of the PCM1704, but you really should try this. Having already designed your main-board outputting right aligned, 7 delay right channel, 39 delay left channel, which from memory, is exactly what is needed for a 1704 design, without any changes. So an optional 1704 daughter board using your stackable design would be really cool! Sure, it means also adding a negative supply for the DAC chips and it would mean having to use an active output stage...... I'd buy a complete kit plus an optional 1704 daughter board if it was available........
Old 26th November 2012, 06:00 PM   #19
DDDAC Audio
exactly my thoughts... mainboard is ready to go ;-) that is the advantage of modular work .... Of course I do see issues in the extra supply and stage, but hey, this is hobby and I was already thinking what to do next.... :-) no promises though
www.dddac.com
Old 26th November 2012, 07:08 PM   #20
Of course, the other issue is cost. Using 4x K grade chips for 2 channel +/- @ $75 each, is $300 per daughter-board. A little more expensive than a pair of 1794's.
BTW, I just ordered a complete 1794 kit from your web store. Will be interested to hear how it compares to my own NOS DIY DAC's. I'll probably use Salas shunt regs for the power supplies and although I'll give it a go with passive out, I'm more than likely to drop the I/V resistor value and hook up a tube output stage...... CCS'd 6C45, or triode connected EF810 or d3a. We'll see.
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
