| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#181 |
#182 |
as far as I heard, or read on Audio Creative site, for balanced output you don't need output capacitors. Dick (one of the owners of Audio Creative) tested a TVC "preamp" with balanced input and he directly plugged the dac into it.....and he was very, very enthousiastic about that. Stil have to try that too with a different preamp myself. |
#183 |
damn you guys with your pictures... i'm considering about getting DDAC myself too but you know how the students pockets are
![]() *hopefully* i'll order it in summer |
#184 | |
![]() the DC voltage between the POS and NEG output is indeed very low, just a few mV or sometimes even below it. If you use only these two to connect to a balanced system, than things are fine, as for DC blocking. but, you should not connect the common terminal in that case, as than you will see two times 2,7 Volt DC. in this case you need the output capacitors. I know from one DDDDAC builder who is using a tube amplifier stage directly after the DAC and actually uses the DC voltage in the bias from the first tube, avoiding coupling capacitors.... there are several possibilities and situations. Every one should check his specific situation and make the appropriate circuit connections. in doubt, just email me ..... |
#185 | |
![]() on the left right question. if you check my circuit diagram, you see on page 2 at the right the connections to the dac. they are indicated as right and left channel. the left channel is the one with the most delay ... hope this helps? the resistors are needed to do the DC biasing of the DAC output, so they have to stay. I also use a secondary load of 10k.this has been very arbitrary and can be left out or lowered or whatever. it is only to dampen the transformer a bit for the small peak round 200kHz. I could not hear a difference, but could measure it, so I left the 10k in to go kind of sure ...
#186 |
Hi Doede.
Thank you for your explenation. Regards Zjaakco |
#187 |
I have placed my order for the kit of parts and will look forwards to putting it together.
No doubt I will be back here later for advice ....
Alex H |
#188 |
DAC Kit arrived yeesterday. Quality of boards is truely excellent ! Will start assembling this evening.
Many thanks for repsonse to balanced output query. Regards |
#189 | |
and.... keep posting pictures
#190 |
| FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS | 2A3SET | Swap Meet | 5 | 15th August 2012 04:52 AM |
| FS:USB DAC real 24/192 (maybe groupbuy) | ANADIGIT | Swap Meet | 242 | 17th February 2012 01:31 PM |
| Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output | AWaudio | Vendor's Bazaar | 3 | 2nd January 2012 12:44 PM |
| GodDAC - 192/24 USB DAC | BizonGod | Digital Source | 36 | 30th June 2011 03:16 PM |
| 24 bit/192 kHz via USB? | gentlevoice | Everything Else | 3 | 22nd December 2008 06:24 AM |
