A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input) - Page 186 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th May 2014, 07:50 PM   #1851
I can already state with great certainty that the Panasonic Fc equipped dac board sounds richer, with more complex harmonics and still crisp and tight, than the Nichicon Muse board
best
Leif
Old 17th May 2014, 03:00 PM   #1852
carlsor is offline carlsor  United States
Leif,
Did you mean 10pf Micas? The 10nf micas are huge and expensive.
Old 17th May 2014, 06:08 PM   #1853
sry yes
Old 18th May 2014, 10:20 AM   #1854
sry checked again and its 1nF Silver Mica
best
Leif
Old 18th May 2014, 10:39 AM   #1855
Zeta4 is offline Zeta4  United Kingdom
Hi
Ive just finished building one of Doedes excellent kits (single version for now) mainly
to research USB cables but thats another story. My version uses an LT1963 with L/C
pre filtering and schottkys etc to supply the WaveIO and a 12V Lead Acid battery to supply the DAC. Ive found that LA batteries vary and the best so far for me are those made by Haze which are very quiet and have low impedance.
Im not saying this is the best set up but its what I had to get me going. Ive read all the
back posts re power supplies with interest. Keep it up.
I also design transformers so Im making some for the DAC with 1-4 and 1-2 step up. The 1-4 hopefully will allow me to try out lower value I/V resistors.
By the way its been said that passing DC through a signal transformer will magnetise it. This is not true as you cannot permanently magnetise a soft magnetic material. There is always a very small amount of magnetism left in the core when the magnetising force is removed this is called remanence. I can just pick up small nickel laminations with a steel screwdriver.
Anyway its perfectly safe to measure the DCR of transformer windings, I do it all the
time. If you dont believe me see the Sowter website under FAQ where he confirms what I have said.
Old 19th May 2014, 08:32 AM   #1856
dddac is offline dddac  Germany
Interesting point on the magnetizing. this is very reassuring! thanks for sharing with us.
www.dddac.com
Happy listening and building
Old 19th May 2014, 08:38 AM   #1857
comment on earlier post.....
please check your facts before writing negative comments...
pricing went up 10 Euro to cover the VAT which needs to be payed as they are a true company....
in hindsight, I might have been a bit harsh here, which was never the point of course.
I do like to emphasize that Audiocreative is, other than me, being private person, a real company and need to pay VAT. for this reason prices had to go up. we have made sure this was limited as much as possible and med the increase low, like 10 euro. Exchange rate differences compared to past might trouble comparison as well for those outside the EU. I still believe the value for money for these kits are good
for Thommy, no hard feelings of course
www.dddac.com
Old 19th May 2014, 08:59 AM   #1858
rfthon is offline rfthon  Netherlands
Imo a second deck would be the best upgrade.
Old 19th May 2014, 09:02 AM   #1859
Originally Posted by Touister View Post
Hello,
I can not decide myself. Need help
I have a single deck version stock
I am looking for improvements.
My current output capacitors are Jantzen Superior Cap (which I believe average).
What would be the best upgrade of the output stage:
1) CINEMAG 15/15B (POS / NEG)
2) Mundorf Silver Gold Oil (POS / COM)
3) Mundorf Silver Gold Oil (POS / NEG)
4) Change Dale I/V resistors for Vishay Naked or something fancy (in addition of another tweak)
Additional question: Where can I find the power supply tweak?
Sorry, in reaction of above question.
Old 19th May 2014, 09:19 AM   #1860
stijn001's Avatar
Originally Posted by leifchristensen View Post
....the Panasonic Fc equipped dac board ....
Did you replace "all" the caps on the DAC board with these FC's with what/same values?
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 05:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 01:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 04:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
Copyright 1999-2017 diyAudio
