A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 25th February 2013, 04:12 PM   #171
crazyfrog is offline crazyfrog  Canada
Originally Posted by Bas Horneman View Post
One of my sons. Helping with the denuding of the caps. He got to solder as well and really enjoyed doing that.
Ha! Ha! How much did you give to him?
Old 25th February 2013, 04:21 PM   #172
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Nothing. He owes me a lot of money. Besides he was begging me to assist with something.
If you can see the speaker cone move...it's not hifi.
Old 25th February 2013, 04:28 PM   #173
I tried it using copper tape on the power supply cap of my Revox B77 reel deck.
I've had copper around my psu polyprop caps. With one end soldered to ground. Just for kicks as well. Should act as a shield. Anyway. The amp I did that with was dead quiet.
PS: Awating delivery of my order sent by Doede. I will be able to report back when I assemble the DAC.
Did you also order the psu for the WaveIO. That really improves things. Or at least power it seperately with your own psu.
Old 25th February 2013, 07:04 PM   #174
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
+1 DDDAC1794. I love it! Here's more
Old 25th February 2013, 07:23 PM   #175
dddac is offline dddac  Germany
DDDAC Audio
Thanks, these Kind of testimonies Keep me going
best,
doede
www.dddac.com
Happy listening and building
Old 27th February 2013, 06:55 AM   #176
bravi is offline bravi  New Zealand
Hi Bas,
Yes, I have ordered the power supply board as well .
The package came yesterday and hope to start assembling soon.
Cheers!
Ravi
Old 27th February 2013, 09:31 AM   #177
Good luck.
I just ordered the 12v psu as well. Because yesterday I changed the 12v psu from the rakk dac mk 1 psu to the rakk dac mk 2 deluxe psu. The mk1 only supplied something like 170mA and has minimal filtering (Something Dave Davenport later fixed in his mk2) since more filtering gave the sound more body. Anyway to make a long story short. The improvement from mk1 psu to mk2 psu was nothing short of stunning. Suddenly I had George Benson in my room .
So now I want to try Doede's psu. And return the mk2 psu to its rightful owner the RAKK DAC MK 2. So I can use that in my other system.
Bas
Old 1st March 2013, 11:13 AM   #178
AudioH is offline AudioH  United Kingdom
Default Balanced Output Options
Hi All,
after following this thread I've taken the decision to order a kit. It is on its way and initilaly I will build it as is with the single ended outputs. Can anyone recommend an add on board or circuit that would provide balanced outputs though please.
Old 1st March 2013, 12:31 PM   #179
zjaakco is offline zjaakco
Hi Doede,
I have read your explenation on your site, and make mine decision to make one.
Words are words, but still there is something , I think your design is right.
Mine knowwlegde is not sufficient to design the delay in the I2S line.
So, I have order a waveIO board, and collecting / buy parts.
Still a few questions, I can't determine what is the L or R channel, i have read the
blue line in the delay circuit. and,
you use a output trafo, are you still use the A B iv resistors on that position, or
a ristor on the sec side?
I have good experiens with an outputtrafo.
Zjaakco
Old 1st March 2013, 01:42 PM   #180
It actually is balanced already.
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
