A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 23rd February 2013, 12:31 AM   #161
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
First things first. The psu was the first thing I tackled. And before I went on to the other boards first a quick check. Yes! It all worked first time.=
If you can see the speaker cone move...it's not hifi.
Old 23rd February 2013, 12:35 AM   #162
Next step the dac itself.
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)-4-jpg
Old 23rd February 2013, 08:54 AM   #163
dddac is offline dddac  Germany
DDDAC Audio
you actually peeled off all the capacitors? wow, looks neat ! very sofisticated
www.dddac.com
Happy listening and building
Old 23rd February 2013, 08:59 AM   #164
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
Here's the state of mine at the moment. As I await for the power supply kits to arrive, am using a MUSE linear psu to supply 12V to the dac board. Still undecided how I would like to case mine up.
Old 23rd February 2013, 10:42 AM   #165
IanS1 is offline IanS1  United Kingdom
Originally Posted by dddac View Post
Great! and thanks, more to follow I hope
this grounding of the negative is intriguing...
I will run some AP test over that and post back if it does any measurable thing as well, which might give a clue why it sounds better? Ian, how would you describe it?
Grounding of the Negative seems to add more weight/scale to the sound is the best way I can describe it. I don't have any scope equipment here to take any measurements but it definitely sounds better in my system and to my ears.
I look forward to seeing the results of this change tested on a scope when you have time Doede.
Old 23rd February 2013, 11:13 AM   #166
dogears is offline dogears  Philippines
I have to agree
Old 23rd February 2013, 02:39 PM   #167
I have to agree
All credit goes to my son
Old 24th February 2013, 08:50 AM   #168
bravi is offline bravi  New Zealand
Default Removing capacitor jaclets
Any reason for removing plastic covers of capacitor?
Cheers!
Ravi
Old 24th February 2013, 10:56 AM   #169
Hi Ravi, No real reason. Just heard some people say it sounds better. 47labs and others. My attitude if asked if I believe in that. No, but I'm told it works even if you don't believe in it.
Old 25th February 2013, 08:40 AM   #170
Hi Bas,
Thanks for the clarification.
Another tweak ( read in the Musical Fidelity upgrade description in their website) is wrapping a band of copper around the power supply capacitor- apparently it suppresses resonances.
I tried it using copper tape on the power supply cap of my Revox B77 reel deck. I have a feeling it may have improved things (I suspect a bit of belief is required). Any way, the good part is that it is easily reversible.
Cheers!
Ravi
PS: Awating delivery of my order sent by Doede. I will be able to report back when I assemble the DAC.
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
