A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input) - Page 16 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd February 2013, 02:04 AM   #151
dogears is offline dogears  Philippines
Hi Bas (Lightyear),
The one being sold is the SPDIF version. I am hoping the price would go down substantially but yes, the price is quite high for a reference but the BMDAC1 is one of the most common reference in reviews.
I've been eyeing the ODAC as well since I already have the O2 amp.
Thanks much for the suggestion... I might just go on with the preorder
Cheers.
edit: I forgot to mention that I also need a preamp for my AKSA power amp so I thought the DAC1 is a good choice since its already a very good DAC/PRE.
Old 22nd February 2013, 05:52 AM   #152
dddac is offline dddac  Germany
hi Dogears Look forward to your Feedback later when you have compared the BMDAC1 with the DDDAC1794. which configuration do you have? ps please keep the pre-amp thing out of this thread. I Ike to keep it as clean as possible, seeing some other threads here ;-)
www.dddac.com
Happy listening and building
Old 22nd February 2013, 05:57 AM   #153
Noted chief DD But I'd like not to get that BMDAC1 due to the additional cost I'll pre-order the E-DAC however and rest assured I'll be posting feedback here. In the meantime I'll still waiting for the go signal :P
Old 22nd February 2013, 07:13 AM   #154
Great, I would really would,like to see some images and reviews here. I know that they are out there
on another note: there has been some questions and comments about the quantization noise with my dac, as I am using the same clock for the bit clock as well for the master clock ( remember, this was done to avoid the digital filter). I have done several tests and am almost completed ( need to understand it a bit better as well, so what to measure?). I will post some images from the AP system next week. I can already say, that indeed you can actually see a correlation between sampling frequency and the Quantization noise. also, that it is well within limits. never the less a very interesting aspect. I still want to do some listening tests around this theme. stay tuned
www.dddac.com
Old 22nd February 2013, 12:42 PM   #155
Some pictures....her with one deck.....more to follow
Old 22nd February 2013, 01:46 PM   #156
IanS1 is offline IanS1  United Kingdom
Default Photo's
Here's a few photo's of my recent build.
I'm using Doede's SPDIF board as my main source being fed by a modified Sonos ZP80 (PSU Mods with Paul Hynes linear regulator boards). I started off with one DAC board and two PSU's but now have four boards and three PSU's. I also have the Mundorf Silver/Gold/Oil caps on the output and I've also grounded the neg outputs.
Old 22nd February 2013, 02:07 PM   #157
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Thanks for posting the pics guys!
Old 22nd February 2013, 03:16 PM   #158
Great! and thanks, more to follow I hope
this grounding of the negative is intriguing...
I will run some AP test over that and post back if it does any measurable thing as well, which might give a clue why it sounds better? Ian, how would you describe it?
www.dddac.com
Old 23rd February 2013, 01:22 AM   #159
You'll never guess what the postman delivered today...
Iphone 4 as size reference. Quite suprised by the size of the psu. And the transformer. Hence the reference.
Old 23rd February 2013, 01:28 AM   #160
One of my sons. Helping with the denuding of the caps. He got to solder as well and really enjoyed doing that.
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 05:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 01:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 04:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
Copyright 1999-2017 diyAudio
