A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input) - Page 12 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd January 2013, 10:24 AM   #111
IanS1 is offline IanS1  United Kingdom
Have just ordered my complete kit with 1 DAC board, Wave I/O, SPDIF board and PSU's.
Looking forward to having a go at my first DAC build project but with my limited electronics knowledge I might need some advice on the switching for USB/SPDIF inputs. Any thoughts to get me started?
Old 3rd January 2013, 02:54 PM   #112
dddac is offline dddac  Germany
Actually the spdif board allows for this. it has an auxililary i2s input which can be selected. it is all the board and in the kit.... better download the schematics from the dddac1543. there you can see how it works. you can also send pm of course
www.dddac.com
Happy listening and building
Old 3rd January 2013, 03:03 PM   #113
OK, thanks I'll take a look.
Old 3rd January 2013, 07:24 PM   #114
and here is a small sketch / drawing how to connect it as the spdif board has relays on board to switch between I2S from the spdif decoder or the aux I2S input
www.dddac.com
Old 5th January 2013, 04:25 AM   #115
The below linked thread will likely be of interest to some participating in this thread.
Testing the pcm1794
Ken
Old 5th January 2013, 05:49 PM   #116
clivem is offline clivem  United Kingdom
Doede, have you picked up on this?
Assuming you are only using a SE out from the DDAC, grounding the neg out while utilizing the positive, (rather than it being tied to earth by 133R but otherwise unused), results in a ~3db reduction in 2nd harmonic from the pos out.
Old 5th January 2013, 06:17 PM   #117
Default Oscillation at LF80 output
I had oscillation around 200 KHz. It needed more than 100 nF. 0.47F + 0,1 F (already there) was necessary at least on my board.
Old 5th January 2013, 06:32 PM   #118
I have something similar and it works well. Just replaced some parts by something "better" (few Jamicon 100F by Nichicon organic caps for exemple). However, you have to forget the ribbon cable for signal wires.
Old 6th January 2013, 06:29 AM   #119
Thanks for this Input. I will check (measure) later on my own DAC if it is the same here. The filter which Comes after the Regulator (LC) filters -70dB at 200 kHz, probably hence it is not noticed on the analog side of things. But as said, let me check this. Better to have no oscillations left over on the Regulator of course. Will do some tests and chime in later today
www.dddac.com
Old 6th January 2013, 07:09 AM   #120
mmm, need to check (measure) this again. I believe I tried and this messed up the DC bias of the other DAC output.
so, if you ground the not used output, what DC voltage did you get on the used one? did you measure this? Will check myself as well
PS: I use the transformer output a lot, so no Option for me anyway
www.dddac.com
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
Copyright 1999-2017 diyAudio
