Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th November 2012, 02:40 PM   #11
twest820's Avatar
Originally Posted by marce View Post
Curious as to how a well designed DC supply can alter the sound, it is DC after all.
Try here and here for intros on how amplifiers interact with linear supplies. (Caution: links contain numbers and graphs which may not be appropriate to bring back to this thread, not least because the calculations are for different design targets. )
Old 26th November 2012, 04:27 PM   #12
marce is offline marce  United Kingdom
Cheers Twest820.
Maybe what I should have said is that for ultimate fidelity I belive that you have to design the PSU as part of the system, not a seperate entity.
Old 26th November 2012, 09:13 PM   #13
TNT is offline TNT  Sweden
TNT's Avatar
Well, it's the DC that becomes the signal, isn't it?
Old 27th November 2012, 06:14 AM   #14
Lets not go down that path, I have worked on numerous electronic systems over the years including instrumentation based analogue systems such as Daresbury in the past, and currently a 24bit 50 channel ADC based design. All systems have to have supplies, more often than not DC so dont try and patronise me over the DC becoming the signal, no the DEC is modulated in some way to become the signal. If you power supply is affecting sound quality then it is either badly designed or is the wrong supply for the amplicfication stage that follows.
Read my quote, "a well designed".
Instead of arguing over the supply of a supply wouldn't it be better to design the supply and the rest of the system as a whole.
Also I though this part of the discussion was over and we could move on to the digital side, wich should be interesting.
Old 27th November 2012, 11:09 AM   #15
DF96 is offline DF96  England
The danger for this thread is that some might see it as trying to 'go beyond' conventional good engineering, when the real problem is that conventional good engineering might not yet have been attained. Once attained, it might be found that there is no 'beyond' to go to.
If it addresses real issues, with real understanding, then it will be worthwhile.
Old 27th November 2012, 11:48 AM   #16
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I don't see any danger in people's false perceptions of this thread myself or I'd not have started it.
@marce - I agree, much better to consider the power supply an integral part of the whole system, not just bolt one on at the end. The aim is indeed a well engineered system, not just well designed. Well engineered to take into account best SQ for the price.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 27th November 2012, 07:31 PM   #17
Pano is offline Pano  United States
Pano's Avatar
I certainly know what works well for me and doesn't have the typical digital sound. The DC supply for the analog section of the DAC chip makes much more difference than I thought it would, so putting some effort there really does pay off.
Take the Speaker Voltage Test!
Old 27th November 2012, 09:20 PM   #18
TNT's Avatar
... If you power supply is affecting sound quality then it is either badly designed or...
qed
Old 28th November 2012, 05:59 AM   #19
abraxalito's Avatar
Just recently found this (old) paper which tells the story of what happens when a digital system isn't engineered properly, that is holistically, taking into account end-user feedback, but rather by the numbers. The numbers in this case being a particular metric chosen to characterize the machine's safety. Here's the relevant paragraph from the pdf (which is long, but fascinating reading): http://sunnyday.mit.edu/papers/therac.pdf
Old 28th November 2012, 12:20 PM   #20
That is a classic software malfunction story. I'm not sure what relevance it has to digital audio.
Tubes Numbers kmscouts Tubes / Valves 3 30th September 2012 04:19 AM
Confused by the numbers alexmoose Tubes / Valves 52 7th August 2006 03:06 AM
Still can't get reasonable numbers mashaffer Multi-Way 13 10th July 2006 04:55 PM
Where did these EL84 numbers come from? Sherman Tubes / Valves 2 13th June 2005 06:53 PM
Copyright ©1999-2013 diyAudio
