Modifying the Russian TDA1543 DAC off eBay. - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th December 2012, 05:19 PM   #31
freax's Avatar
Originally Posted by freax View Post
Jimi Hendrix - Castles Made Of Sand (FLAC)
Is truly truly amazing, the stereo imaging is amazing, Jimi is up in the air at the front of the room talking down to me, and he fades into the right or left channel, aswell as swappiing positions with the guitar, I even heard a lower level of voice in there that was completely muddled before on the old resistor values.
It sounds very very analog.
Difference = Slightly more muddled when compared to using the russian caps, I didn't pick this up while watching 12 monkeys.
Stereo seperation is all over the map, it doesn't sound much if anything like it used to.
Jimi Hendrix - I Don't Live Today
Could copy even the very low level voices at the end of the track.
Vocals have a deeper throat sound to them, like they are coming from the chest more.
Not as good as when I first heard it.
Jimi Hendrix - Up From The Skies
Groovy maaaan.
Strangely, sounds better, there is a guitar which sounds really natural now with this capacitor change, whereas before it sounded more fake before, like it was being plucked without any force.
Vocals sound pretty natural, but still in the slight chance that you get to listen to Jimi alone without the guitar, he sounds muddled again.
So conclusion is that, for movies, electrolytic appears to win, so far, but for music, the russian polypropylene in oil caps win.
I think I know whats going on, with compressed audio, electrolytics appear to respond better, whereas with normal CD-sourced music, the polypropylene's win.
Reasoning for this is: Compressed shoutcast sources sound /great/ with these electrolytic caps, whereas before, yes they did sound good but they also sounded fake, but these electrolytic caps appear to 'hide' the bad parts of compressed audio and just let me enjoy it more....
I'll have to observe/listen to it for a week again to be sure on all of these points.
Nelly Furtado - Whoa Nelly! album sounds improved.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 5th October 2013, 07:23 PM   #32
@freax....is this page still alive? And are you still using the russian NOS dac? Because I'm think about buying one instead of the nos lite ah DAC.
Old 19th June 2014, 12:22 PM   #33
freax's Avatar
The russian DAC kit was a waste of time because the capacitors used in the I/V stage which were shipped with it made it sound exceptionally muddled to the point of lunacy (to the point that you could only play 50s-60s music through it.
However it did sound great with the goldy tin coloured 0.022uF capacitors.
So the dac was modded a day or so after getting it and it is no longer the original design.
I pulled the DAC apart and am currently reusing the components for a dedicated rackmounted case with homemade/dremel drawn PCB boards. Waiting for parts to arrive from HK.
I'm currently studying a suitable shunt regulator which will enable me to have the least possible noise feeding the analog stage of the TDA1543 chip, I've even considered doing away with a voltage regulator and simply using a variable Rheostat to adjust the volatage to within 4.0v-8.0v to feed to the TDA1543 chip. The main reason for this is that I would theroetically get the performance of a high end 4uV super voltage regulator without the needed silicone. Just simply 12vAC Transformer -> Rheostat -> Bridge Rectifier -> Filtering Capacitor -> RC Stage -> DAC Analog stage.
I've also sourced a genuine TDA1543 IC from a Sony CD player which will after an initial power-on test of the new DAC will be taking the place of the (assumed) fake TDA1543 which came with the Russian DAC Kit.
I want to use the two russian 0.022uF capacitors which I added to the Russian DAC kit, which was the first modification that I made. The goldy tin poly capacitors. I will definatley be using substitutions and making corrections to the circuit after I'm done building it too but one thing which will survive the transition is the handwound chokes, I think the original russian guy who designed this was onto a really good low budget and worthwhile way of isolating each digital stage from one another. The wax paper coated iron cores impressed me, it saves having to buy dedicated premade chokes.
My suggestion to you that if you are still considering buying the Russian DAC kit that you should consider building it by sourcing the parts yourself and winding the chokes yourself on a PCB project board of your own, but if your just starting out then the Russian DAC Kit is worthwhile. But while it is an exceptionally simple design its main and only flaw is that it is too expensive for what you get. Though you could argue it is good value for money if your just starting out its only flaw is that the pcb board really lets it down in the quality control area, the traces are too thin.
The thin traces on the Russian DAC board for example started to break off when I tried modifying it and I had to add copper wire to replace the traces.
I will want to be making the best possible DAC I can on my budget while keeping to the KISS principle (Keep It Simple Stupid) with the use of common and easily obtainable discrete components. Enabling anyone to build this DAC, at any budget, without having to source Unobtanium components at high cost and not having to do a great deal of head scratching.
I therefore christen this new one "The Anarchists DAC". Because I have no idea how its going to sound, I have no idea what I am doing and I don't paticularly care. I just want good sound. And will be borrowing from everywhere in the design of the shunts/power supply and using random components that I have on hand which may or may not be the "right" types to use.
I currently have the revision 1 shunt volt reg in LTSPICE That is where I am at the moment.
Let me give you an idea of what kind of budget I'm working on, I'm hesitant to buy another roll of solder because it will be expensive and I'm quickly running out. But don't worry I'll buy another roll, just got to find the right time to do it.
Old 19th June 2014, 01:05 PM   #34
Flied Egg's Avatar
I would avoid the kits as they are largely a waste of time.
You can point-to-point build a really good Tda1543 - take a look at
Pushing the limits of TDA1543 NOS DAC
There is a simple schematic supplied by Uncle Leon which is a great place to start.
The key points for a really good sound from the Tda1543 are:
1.Low noise regulators (not LM317/78**) with the small decoupling caps placed directly on (or very close to) the chip. Use 2 separate regulators for the CS8412 and 1 for the Tda1543.
2. EC Designs made a critical discovery - don't use pin 7 on the DAC chip. Leave this floating as otherwise it brings a lot of noise to the party. You simply replace the I/V resistors as shown with 680R resistors which are the connected to the +ve of a 3v battery instead of ground. The -ve of the battery connects to ground.
I have also incorporated a few tweaks to the input spdif and Coupling Caps and the final sound is well worth all the effort.
Old 19th June 2014, 01:22 PM   #35
freax's Avatar
I've been eyeing off that design by Peter Daniel for ages but cannot fathom the cost involved sourcing each individual resistor so I'm trying to go my own route instead.
Yes this is the path which I am going towards. Modularity of each chip on a dedicated PCB board is something that I desire and a dedicated feed to each chip. Taking more care for the one going to the TDA1543.
Also thank you for the Pin 7 idea.
Chokes have also been used elsewhere in other DAC designs, for example:
The Extremist DAC
I've also done some research into the sound of SLA batteries but that may be one thing which I will have to keep in mine as I would like to have battery backup. I could substitute with supercapacitors, interest in that is on the agenda.
Simple Voltage Regulators Part 1: Noise
Another thing which I have researched is shielding and modularity.
The shunt volt regulator which I'm considering using is this 2n3055 voltage regulator schematic as shown here:
http://www.eleccircuit.com/small-5v-regulator/
Schematic Number 2 on that page.
It has:
1) no Zener diodes.
2) Easy to obtain components.
3) As simulated in LTspice is by design a low pass filtering circuit, probably because of the 2n3055's inability to easily pass RF?
Both that are advantages in this idea.
Old 19th June 2014, 01:57 PM   #36
Flied Egg's Avatar
I just use carbon composite resistors and reasonable quality capacitors - the DAC cost 20 including coupling caps.
I also built 4 of the Bobken series regulators mentioned in that thread - they cost around 20 each.
Add to that a Jocko Homo input buffer (takes most of the remaining harshness away) for 15.
Plus a couple of transformers and the lot cost 130.
(components mostly sourced from China via eBay.com in The States if they are not on your local ebay)
Old 19th June 2014, 02:12 PM   #37
freax's Avatar
In LTspice It shows me a steep dropoff after 100KHz (5.4nV/Hz) and almost no gain (0.6nV/Hz) at 3.5MHz.
Neat.
Old 21st June 2014, 08:34 AM   #38
@freax, somebody said the same about the Russian DAC. So I never bought it. Instead I bought a Chinese 1541A DAC, the gold 1541 dac.
That was actually a good choice. It sounds much better than the lite DAC. I only changed the output caps and used 2 lechlance ppm mkp caps instead. And also put in a original TDA1541A IC from a old broken Arcam CD player.
Old 19th September 2014, 09:57 PM   #39
Ola is offline Ola  Estonia
Gentlemen, TDA 1543 data sheet says it's voltage output, not current output. So what's the I/V you are talking about?
Old 20th September 2014, 07:51 AM   #40
Default TDA 1543 current outputting thing
Sorry, last night I was tired and slow thinking - don't take my message seriously....
8x TDA1543 & WM8805 DAC on Taobao (on Ebay soon ? ) KlipschKid Digital Line Level 13 15th February 2013 12:50 PM
Russian 1543 dac pcb on ebay PreSapian Digital Line Level 10 1st November 2012 06:06 PM
Modifying my DAC BcA187 Digital Source 5 31st March 2012 10:28 PM
Just bought some of those Russian paper/oil caps off of ebay aletheian Parts 31 23rd October 2005 08:46 PM
Ebay Russian teflon caps tiroth Parts 7 27th May 2002 06:39 PM
Copyright 1999-2017 diyAudio
