| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I'm working on some DAC board using old style DAC chip like PCM56, PCM63, PCM1702, PCM1704, AD1862, AD1865, TDA1541 and TDA1543 in NOS mode.
I'm building these boards to be used with Ian's Fifo buffer (Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter) and Ian's I2S to PCM daughter board (Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board) These boards can be configured as single or balanced mode and use a single resistor as IV convertor, preferably an high quality resistor such as Vishay bulk metal foil. Then I'm planning to implement a Zanden filter (Zanden Parallel DAC Questions) and finally a tubes line stage. I would like to avoid any capacitor in the signal path, so I'm thinking to work around a totally dc coupled tubes line buffer. I'm seriously thinking to a Circlotron circuit, since in balanced configuration I can get opposite phase signal to drive directly the Circlotron. But any other dc coupled tubes design could work as well. Any suggestion will be appreciated. Andrea Last edited by andrea_mori; 29th October 2012 at 05:09 PM. |
#2 |
Sounds nice but you would have to decide on a DAC chip first. I think its too late to do a Zanden stack though, as even the lowly PCM56K is not available in quantities. Only the PCM1702/4 can be bought of the shelf, go with 2 per phase.
Since most all of been done to death anyway maybe (with Ian's I2S-PCM) its time for a deep dive into an NOS PCM1704 board. Its the only one that can take hirez audio. HD-Tracks to an NOS PCM1704 may be very interesting. I can show you how to set up the PCM1704 to work with passive I/V. Ideally it would be laid out to plug right up to Salas regs. As far as the tube stage if you really want dc coupled Circlotron output you will need a timer relay in the signal path, don't know if thats any better than a cap, but I'm interested to see what you come up with. Personally I'd stick with the proven WE417 anode follower, or possibly a spot on the board for a nice stepup transformer then a DHT like the 4P1L (most linear tube available), or skip the transformer and two DHT's loftin white. Lot of possibilities. But I think your best bet is the PCM1704, lot of people listening to 24 bit music nowdays and yours would be one of the first NOS dac's that could play hirez without nasty truncation and no dithering required. |
#3 | ||||||||
Hi regal,
The second option is a single tube with output transformer like Lundahl LL1674 or LL1930. This could save complexity, probably I could eliminate anti-aliasing filter, since the transformer will cut the upper frequencies. Quote:
Andrea |
#4 |
Just got some 5842, some C3m and some 5687.
The idea is a differential pair based on 5842 or C3m in triode mode with a CCS, direct coupled to a 5687 circlotron output stage and direct biased from the differential, that also act as phase shifter to drive 5687 bridge. No transformer, no caps. DAC filter like Zanden filter, to minimize the phase shift in audio band. Anyone knows where could I get some custom values air core inductor? |
| DAC IV stage schematic | mahen.jnk | Digital Line Level | 1 | 12th August 2010 03:59 PM |
| How far can IV converter be from DAC? | philpoole | Digital Source | 7 | 30th April 2007 03:05 PM |
| THAT2180 used as current buffer / in IV stage? | ash_dac | Digital Source | 0 | 29th May 2006 12:49 PM |
| Op-amps in IV, filter and buffer stages of a DAC | Dr.H | Digital Source | 1 | 2nd June 2004 03:20 PM |
| A single supply, 2 transistor DAC-IV stage. | Brian Guralnick | Digital Source | 26 | 4th November 2002 06:50 PM |
