active filter frequency fc and phase relationship
Old 15th November 2012, 10:40 PM   #31
qusp is offline qusp  Australia
qusp's Avatar
as I understand it, it was significant for the first draft lme49710 or 20/lme49600 reference design headphone amp, or maybe it was just the lme49740, it resulted in offset at the output and for a while the lme49600 had the reputation for being a bit risky with offset, when it was the input stage or servo causing the problem, not the buffer.
no such problems with the 49990
talking real reported problems here, not datasheet specs, using the PCB artwork supplied by them
btw input bias current
Old 15th November 2012, 11:50 PM   #32
twest820 is offline twest820
I happen to have an LME49600 based triamp in my living room with the controlling op amps being a 49710, a 49713, and a 49990. None of the measurement gear I have access to---RTAs, oscopes, 6.5 digit meters, spec ans---is able to measure any difference between the three channels except for noise floor; the op amps are better than the measurement equipment. They're also better than the measurement setup; for every EMI source I turned off (lights, furnace, laptop, etc.) and bit of shielding I added the noise floor just kept going down. I gave up when the meter was hitting the bottom of its range (100nV) and the highest peak on the spec an was 60Hz at -127dBV. This is on a toner transfer grarage fab PCB using scrap FR4, 20mil DRCs, and vias made by feeding wire through the board.
I'm not seeing how input offset current or voltage would produce a meaningful offset on a 49600's output in a well implemented composite amp. The op amp's input offset voltage will be reflected at the 49600 output but the 49710, 49720, and 47940 all have max voltage offsets of 700uV, which is hard to beat in an audio op amp---usually it's more like 2 to 5mV. Similarly, the offset currents are 5-11nA typ so you'd have to have a strangely high feedback impedance (>10k) to get above the voltage offset. Got a link? I'm curious if perhaps someone rigged for gain and miscalculated when deciding not to add a DC servo.
Post 29 states input offset, as does the first part of post 31 (though whether it's offset current or offset voltage is not specified). FWIW, the 49710 input bias is 7nA typ (versus 30nA typ for the 49990 and 250nA typ for the 797) so it's comprable to input offset current.
Old 15th November 2012, 11:51 PM   #33
qusp's Avatar
thats why I clarified. but look, do you think you could quit the niggling? I couldnt give a toss about it, i'm not going to use them, ive never enjoyed the results, ive stated it could just be personal bias and i've stated a distant recollection of other peoples reported results and measurements with the chip including Kevin Gilmore and various people here and headfi who have built the design I mentioned (uses half the chip as servo), i'm afraid I give that more credence than you forever countering with datasheet numbers. maybe its got more to do with national's flawed reference design than the chip itself, but I honestly dont care enough to investigate, you are free to do so...
the reported offsets are well into the mV range, I get the feeling its the high servo gain combined with the input bias current, something like that, so the servo causes more offset than if there was nothing. but I really dont care. I dont like them, I have my fill of opamps and I have a rack of unused opa1632, lt1028, ad797, lme49990, lme49610, opa827, lt1128, lt1037 etc etc so I dont need to investigate.
Old 18th November 2012, 09:51 PM   #34
Hmm, yeah, the 1M input resistors to the servo in National's eval board are an odd choice. Assuming 1% tolerance resistors input bias current will generate up to 10mV typ offset on the output and input offset current another 11mV typ, with a worst case corner of 274mV. Ow! That's an unfortunate fail on the part of National's apps engineers but not a problem with the 47920 or 49600 per se (qusp may not care but I find this interesting enough to reply anyway). DC servos normally use FET input op amps to avoid these issues---servoing with a 797 or 49990 would just make the problem worse---so a TL032 is a substantially better choice if a servo is required (or the more common TL072). In this case an unservoed 49720 should yield an offset 400uV lower than a TL032 typ and 1.8mV max, which is why my 49600 triamp is unservoed.
The closest thing to a servo tank around a DAC is the midpoint voltage reference, which is substantially lower impedance. DACs' ability to source current into the reference is often not speced but I'm not aware of any cases where the current draw of BJT input op amps using the reference for output buffering has caused problems. So, to go back a few posts, 497nn series parts all still seem fine options for DAC output buffers.
As for the rest, I'll repeat my previous ask to take any personal issues with a post to PM.
Old 22nd November 2012, 09:19 PM   #35
GLENZWORLD is offline GLENZWORLD  Canada
Originally Posted by twest820 View Post
Tek 2215 is a good starting point.
See references linked previously.
That's part of it, though non-noise currents can easily dominate---ground traces/wires/planes/whatever have nonzero impedance so the potential varies across them. For example, a power amp usually pulls more current than a DAC or preamp so its ground voltage changes more with the charging pulses through its bridge. Since an unbalanced interconnect has 0dB CMRR all of the difference between the DAC/preamp and power amp's ground potential is seen as signal at the power amp input. Multiply by a typical power amp gain of 25-30dB and one begins to have a case for why things like power cords can be audible.
Generally speaking if your design has a hard requirement for better than 0.5% Susumu RRs or similar it's probably not the right design---think twice before spending more than 10 or 11 cents on a resistor. That said, 0.1% RGs are under 50 cents in small quantities so they can be attractive if one's in a mood to splurge a little.
I might be forgetting something but I think the most expensive resistors I've ever bought are Vishay RH050s for power amp testing---for DACs if you need more than a 1/10W 0603 there's a decent chance you're doing something wrong. That doesn't mean the possibility of buying matched quads isn't pretty cool but, let's be realistic, in most applications it's like buying a $100 bottle of wine rather than a $10 bottle---you do it because you want to, not because you need to.
Oh, sure I agree. Though either of these op amps is arguably overkill; the 49990 or 797 doesn't move THD+N much to the left of a 49710, 49722, 49724, or 49740.
sorry took so long but I had to do some reading
I think I get the basics for cmrr but have not checked datasheet to compare
it is kinda (I say that loosely) like feedback noise cancellation but between + and - inputs
Is 2215 first analog with digital display?
so try this design with cheap resistors before paying 15 bucks EACH for z foils
thanks again
Glen
Old 24th November 2012, 03:29 AM   #36
Oi, no problem; 'tis your project after all and it's cool you're reading up. That is indeed a pretty loose description of CMRR. Feedback corrects certain kinds of deterministic errors internal to the amplifier, including ones induced by common mode voltage on the inputs (common mode is the average of the + and - input voltages, the voltage between the + and - inputs is the differential input voltage), but does not reduce or cancel random noise. However, the common mode portion of input noise will be rejected (e.g. ignored) to the extent the amplifier and feedback topology deliver CMRR.
The 2215 has a CRT rather than an LCD.
Old 25th November 2012, 10:12 PM   #37
thanks again for your input
that was a better explanation to cmrr than I have read so far. I still need to do lots more reading just need the time
well I have seen stuff as low as $200 for tektronix with probes so I will probably order one that is tested and has refund
thanks
glen
active filter frequency fc and phase relationshipHide this!Advertise here!
Calculating LPF Fc for Generic Filter maczrool Digital Line Level 2 6th May 2012 02:11 PM
back loaded horn bass frequency phase wicked1 Full Range 12 4th December 2009 12:05 AM
Relationship Between Inductance And Current In Filter Choke mark845 Tubes / Valves 2 6th December 2006 11:58 AM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Gain/phase relationship of amps? Beggar Chip Amps 2 11th September 2003 08:50 PM
