ES9018 I2C controller
Old 12th March 2017, 05:33 PM   #271
jessper is offline jessper
Default solved driver problem
I don't give up when something go wrong. When I connect the controllerboard
to the computer, sometimes a pop up that said driver already installed.
But no virtual comport in the device manager. A search on cd or C:\ give no result. An other popup up and ask for search on the web. This is not what I prefer, you no never where they searh. But I had no more options, so I did.
And whitin 30 seconds the search stop, a line in the device manager disappears
and a line with a comport appears. I stard arduino and yes, the com port shows up in the arduino IDE.
Now I can load the code, I hope so!
Soon I will tell you.
Old 20th March 2017, 06:56 PM   #272
Default load the code
hi
On the picture you can see that on line 288 a fault is stated.
Fault while compiling, and in the black bar which fault.
Mine question, is here anyone who can tell me how to solve this problem?
Thanks.
Old 29th November 2017, 09:08 PM   #273
userguide is offline userguide  Canada
userguide's Avatar
Originally Posted by jessper View Post
hi
Thanks.
If it's not too late, check the Post #236 for the solution:
Old 29th November 2017, 11:25 PM   #274
Default solution
Hi userguide,
Your explaination is right.
The problem was indeed that the libery files not stay in the right map.
When I attempt the last time, different error message appear, and when the stdio.h file (in a map whit the same name) was replaced, to the right map, the error message disappears, but the next error message appear. Again a libery fault.
Then I replace all the libery files to right map and let load again the code, and yes, its going right. So,after a lot of errors finaly a good working controller.
Hi corpius, again thanks a lot for willing to help me with the controller board, still you where very busy whit your study.
Best regards
Old 2nd January 2018, 02:12 PM   #275
Default controller for any audio chip
Hi
It's now about 3.5 years ago that corpius was willing to sell me a pcb board with parts. One of his statement was that he has not much time, study, work etc. I had ask him the possibility to change the code on such way, that the controller for any audio chip is to use. He aswer, that it is not a big problem, only I have no time to do that. Very sad, but a fact.
So, I know that programming is not my cake, I don't like it.
Now mine question, is here anyone who can change the code, so that the controller can be use for any audio chip?
Best regards.
ES9018 I2C controllerHide this!Advertise here!
ES9018 - I2C interface vt4c Digital Line Level 0 4th August 2012 01:12 AM
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 02:44 PM
I2C controller for Audio DSP elnec Digital Source 6 15th February 2008 10:58 AM
I2c Amdio Digital Source 9 29th April 2007 12:05 AM
I2C Controller rehanabid Digital Source 1 21st October 2004 10:02 AM
