ES9018 I2C controller
Old 21st November 2012, 09:04 PM   #131
SCompRacer is offline SCompRacer  United States
Originally Posted by Corpius View Post
Have you tried it yet?
Yes, but only the volume works. I had pulled out the center terminal on the encoder so no push button works to select menu. I am waiting for replacement encoder to arrive. With the holiday Thursday it might not be until next week.
Old 21st November 2012, 11:04 PM   #132
glt is offline glt  United States
Use a separate switch...
www.hifiduino.wordpress.com
Old 22nd November 2012, 03:35 AM   #133
Just to test or fo-ev-a?
Old 22nd November 2012, 11:03 AM   #134
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Yes, that is possible. The IIR bandwidth can be set to Normal (47k), 50k, 60k, and 70k. For DSD it is recommended to set it from 50k to 70k. Use normal (46k) for PCM.
Sabre32 H i F i D U I N O
I'm planning to program it in a way that when the input format is DSD 50K is automatically is selected, but another setting can also be chosen. When the input format is PCM it should select Normal (47k) automatically.
That's sound great.
Old 24th November 2012, 05:58 PM   #135
The new encoder arrived yesterday! First thing I did was drill two holes in the PCB for them two lugs on the switch body. Now it won't twist when I hold the board and snug the nut. I am using the Panasonic EVQ-WTEF2515B rotary encoder that glt suggested.
I disabled the pull up resistors in the Arduino by setting the appropriate two lines of code to LOW. I reset switchbounce interval from 250 to 200. Hardware debounce works better for me. Better control. I get less overshoot, ghost changes, when turning the encoder. With software debounce, after I made a change to a menu setting sometimes it changed back to previous setting even though I didn't turn the encoder another click. I’ll stay with hardware debounce.
One thing the knob I am getting from modushop is 6mm splined so I may have to go splined encoder shopping. Not sure how the Panasonic with the half flat shaft will work with that knob. I had a cavity machined in the front panel around the flange of the knob so it cannot be off center or it will rub.
Old 25th November 2012, 07:56 PM   #136
Corpius is offline Corpius  Netherlands
Corpius's Avatar
I'm using the exact same encoder. Two new encoders just arrived some days ago. I never experience any ghost changes when turning the encoder, but that doesn't stop me from using the hardware debounce.
I do not think that the knob fits onto the encoders shaft. You could order another encoder or another knob. I recently orders some knobs from ebay.
30x22mm Aluminum Knob Solid 1/4 Shaft Volume Tone Control Audio Tube AMP Black | eBay
These have a little screw on the side to fix the knob to the encoders shaft. I will use these knobs with the yet to be CNC'd frontplate
CE-Designs.net
Old 14th December 2012, 08:30 PM   #137
Corpius's Avatar
Default Et viola! The PCB is here......finally
It took a real long time before the mailman showed up with the Prototype PCB. I almost gave him a hug when he handed over the small box from China.
I did a quick check on all connections and all looks fine at first sight.
It fits exactly on my 20x4 LCD and the pins of the 'I2C LCD extra IO' do line up perfectly with the connector pads. Time to do some prototyping tomorrow.
I also have to do some more programming, but most of it is done by now.
Here are some 'showcase' pics of the PCB mounted on the LCD display.
CE-Designs.net
Old 14th December 2012, 08:43 PM   #138
Congrats, really looks very very nice.
Old 15th December 2012, 05:09 PM   #139
Corpius's Avatar
I populated one of the boards today to test if no mistakes where made in the design. All components fit nicely,exept for the 100nf caps I had at home. The pin spacing for most 100nf caps is a bit wider (5.04mm) than the distance between the holes (2.52mm) for the caps. The pins of the caps I had at home needed to be bend straight in order to fit in the holes, but 100nf caps with a pin spacing of 2.52mm can also be bought
I had ordered the wrong package LT1086, so this is not used yet. The meant that I had to power it by bypassing the power input. I used an Arduino for this. All works just like it has to. Now to add the temperature sensor and DIP switch. I decided to use to DIP switch to lock the volume control enable/disabled setting, Stereo/Dual Mono setting and output phase setting. When the switch is set to ON the corresponding setting can't be accessed in the menu. This safety precaution is especially useful when having children around or a wife that is not that confident with electronics or.... to protect it from yourself
I also need to finish the code, It's still not finished because I think of options and setting to add or enhance about every two days. I hope to release the first version next week.
CE-Designs.net
Old 15th December 2012, 05:49 PM   #140
gwikse is offline gwikse  Norway
Very nice. It looks like it will be possible to have a very tidy cable layout. Nice and tidy control solution that fits the rear of a 20x4. Very nice
I like the idea of locking the settings that can harm the system as well. Less likely that there will be any mishaps
JRMC (PC) / ROON (RPI-ROONbridge) | .... DIY ..... | Nordost Heimdall | AP Virgo V
ES9018 I2C controllerHide this!Advertise here!
ES9018 - I2C interface vt4c Digital Line Level 0 4th August 2012 01:12 AM
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 02:44 PM
I2C controller for Audio DSP elnec Digital Source 6 15th February 2008 10:58 AM
I2c Amdio Digital Source 9 29th April 2007 12:05 AM
I2C Controller rehanabid Digital Source 1 21st October 2004 10:02 AM
Copyright ©1999-2017 diyAudio
