WM8805 doesn't work with TDA1543 in hardware mode? - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th September 2012, 03:45 AM   #1
Default WM8805 doesn't work with TDA1543 in hardware mode?
Hi, I've set the WM8805 to hardware mode, with 16bit master mode I2S output.
When 192k/16bit spdif data is feed in, I measured the I2S output rates of WM8805:
BCLK=12.28M
LRCLCK=192K
Since 12.28M=2*192K*32, meaning the output is 32bits?
I read from the datasheet that in hardware mode, WM8805 generates 128fs MCLK with 192K input. And BCLK is 1/2 of the MCLK.
However, 12.28M is far more than TDA1543 could handle(9.2M).
Any way to make WM8805 work with TDA1543 in hardware mode?
Old 28th September 2012, 04:06 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
If you read the datasheet you'll find that 192k only works in software mode.
<edit> At least that's the way I read the datasheet but reading again it says in hardware mode that all input rates are supported. Which is confusing to say the least...
PPS When I was working out how to use this chip, I recall reading that in hardware mode the BCLK is always 64X the sample rate - i.e. 32bits are clocked out per sample. The only way to get 16bits per sample (and hence 32X BCLK) was to use software mode.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 28th September 2012, 04:54 AM   #3
Thanks abraxalito
Yes BCLK is 64X the sample rate.
I'm still confused by the I2S format - datasheet says - 'Word length of 16, 20 and 24 bits are supported'. So 32 bits per sample is not supported, but we do get such output...
If I feed 192k/24bit into WM8805, will it still output 32bits per sample? (guess it adds 8 zeros at the end of each sample)
Old 28th September 2012, 05:14 AM   #4
abraxalito's Avatar
I think that must be referring to the formats of the SPDIF input - it can support up to 24bits (unofficially, I think that's part of the AES/EBU standard). 32bits per sample is not possible over either of these formats - there's not enough space
Yes, that's my understanding - the 32bit frame will get zero padded.
Old 28th September 2012, 08:43 AM   #5
Looks like I have to find an MCU for software mode then.
Old 28th September 2012, 09:03 AM   #6
abraxalito's Avatar
I can recommend LPC1114 - it has hardware I2C and comes in a DIY-friendly DIL28 package. Or for a finished one on a PCB you can't go far wrong with this one for $8 : http://www.mouser.com/ProductDetail/...8XePqj%2fvE%3d
Old 29th September 2012, 08:50 AM   #7
I can recommend LPC1114 - it has hardware I2C and comes in a DIY-friendly DIL28 package. Or for a finished one on a PCB you can't go far wrong with this one for $8 : STM32F0DISCOVERY STMicroelectronics | Mouser
That's nice.
DIT4096 and CS8406 hardware mode audio formats emuman100 Digital Source 1 22nd October 2015 07:51 PM
8x TDA1543 & WM8805 DAC on Taobao (on Ebay soon ? ) KlipschKid Digital Line Level 13 15th February 2013 01:50 PM
How to control SRC4192 in hardware mode? Do i need a pull up or pull down resisiter? benjaminre Digital Source 8 9th April 2012 04:49 AM
DIR9001 + DF1704 Input in Hardware Mode Salar Digital Source 0 22nd March 2010 07:35 PM
CS8405A Hardware mode connection KY Digital Source 0 8th March 2005 01:16 PM
Copyright 1999-2017 diyAudio
