Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Old 13th June 2017, 03:50 PM   #891
Cheng is offline Cheng  Singapore
Hi Eldam,
Yes. The Kali has a u.fl mclk out, just that I'm not sure whether it works with the pcm board.
Hi Ian,
Thank you. Yes it is your isolatorpi in the second & third picture. I did not get them to work on the AD1865 & PCM1702. Don't know whats went wrong, as I assume all I2S signal should be a standard.
Maybe I should try your FIFO to isolate the problem. Or maybe it is the opamp IV, but I remember they work well with my other diyinhk dac.
I like to plan the boards positioning for testing before transferring them into a proper chassis
Cheng
"musicality is not always about high fidelity"
Old 14th June 2017, 07:00 AM   #892
vzs is offline vzs  Europe
Cheng, did you double check that all I2S connections from DAC pins to source board u-fl or OK? also check at DAC pins the required voltages.
Old 14th June 2017, 03:40 PM   #893
Hi vzs,
I have double checked all the u.fl connection from kali > PCM board > Dac board. I do not know the problem is the opamp IV or kali>ian pcm compatibility.
Do I really need a mclk data for ian pcm > dac board?
p.s. I have checked & confirmed the 5vdd and +-5Vcc input to the DAC too.
Cheng
Old 14th June 2017, 04:23 PM   #894
You need a MCLK to I2StoPCM board only, MCLK range can be 128*Fs to 2048*Fs.
I2StoPCM board uses that MCLK for reclocking the PCM signals sent to the DAC board.
So if you play Fs = 44.1KHz music you need at least 5.6448MHz MCLK for the PCM board.
Try to measure the signal frequencies at the DAC pins. I see you have (at least) a Fluke 115, with that you can check LLLR with 44.1KHz music you should see ~44.1KHz on the meter. If you have a better one measure CLK too.
Old 17th June 2017, 03:36 AM   #895
Hi vzs,
Today I tried measured the LLLR pin11/pin14 & CLK pin12 on dac pin (ref to DGND pin13 ).
I got 0HZ at the LLLR.
I got 44.1KHZ at the CLK.
Does that means the problem is with the compatibility of kali & Ian pcm board?
Cheng
Old 17th June 2017, 11:54 PM   #896
Dimdim is offline Dimdim  Greece
It means that you should definitely re-check your cabling. 44.1K at (B)CLK points to a mixup in the cables.
http://www.dimdim.gr
Old 2nd July 2017, 12:30 PM   #897
Hi all,
Manage to get the AD1865 & PCM1702s Dac board to sing with following setup. Can't figure out why it doesn't with the Kali setup. (May try again to confirm)
Rpi>Ian Fifo>Ian Isolator Board>Ian Dual Clock Board>Ian PCM Board >Dac Board>Opamp IV
The reason I got into this project is because I wanted to try old NOS R2R Dacs in simultaneous mode before its all gone in the future And I hope to replace my old cd player (marantz cd63) with HD/Rpi, as the it is so much more convenient.
So far I find both Ad1865 & PCM1702s Dacs set up to sound smooth and detail especially in vocal. My marantz is also very detail and musical, but the sound is abit "on your face", just like other DS dac that I have heard. Next on the test bench will be trying out on different IV output.
Again I would like to thanks Ian for all the nice digital interface boards. It really makes integrating with nos dac so much easier
Cheng
Old 6th July 2017, 05:37 AM   #898
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Cheng, nice build. Where did you get the dac board from?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 6th July 2017, 03:06 PM   #899
Hi Luke,
I am the fortunate few who got the dac core board from vzs who generously donated his extra board from Ian.
Cheng
Old 13th July 2017, 03:19 AM   #900
chansiukwing is offline chansiukwing  Hong Kong
Default TDA1540
Is it possible connecting this old DAC to the I2S-PCB BOARD?
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver boardHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS: Paralleled TDA1541 NOS/OS DAC Board pftrvlr Swap Meet 6 17th April 2011 09:39 PM
AD1865 vs PCM1704 steve jones Digital Source 30 28th December 2008 03:04 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Urgent sale a lot of NOS (produced in 1996) PCM 63 "K" grade! Altmustech Parts 0 26th August 2006 11:41 AM
