Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Old 13th August 2013, 01:31 PM   #511
Tazzz is offline Tazzz
I certainly do not want to come across as demanding anything, but I thought it wouldn't hurt to ask either.
I'm already using a smaller (72cell) Xilinx CPLD to split an I2s stream into left and right and handle the data inversions in my own dual diff 1541 dac.
Old 13th August 2013, 01:42 PM   #512
dvb projekt is offline dvb projekt  Germany
dvb projekt's Avatar
Originally Posted by iancanada View Post
Unfortunately I cant find any working software based real time up-sampling apps which can go up to 384 KHz so far for both Mac and PC, any recommendation?
Ian
Hi Ian,
for the MAC Pure Music could do that including DSD file playback!
  • Up to 384 kHz sample rate
  • Selectable REAL-TIME 64-bit upsampling
  • DSD (2.8 and 5.6 MHz) file playback on any DAC (real time PCM conversion)
Just update the firmware of your Wave I/O to the newest one, witch support 32/384 kHz (for WaveIOs with RevisionID 00331 or higher)
Oliver
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 13th August 2013, 02:41 PM   #513
qusp is offline qusp  Australia
qusp's Avatar
puremusic, audirvana, amarra to name a few for mac
Old 13th August 2013, 07:16 PM   #514
Jackal29a is offline Jackal29a  Spain
JRiver for Windows will upsample to both 352.8K & 384K, if high performance and amzaing flexibility is desired then HQPlayer from Signalyst can do up to 32/1.5MHz or DSD512 for Windows, Mac and Ubuntu and its derivatives but it is expensive.
Old 14th August 2013, 09:59 AM   #515
I do some testing yesterday and could confirm that the I2S to PCM module runs great.
Software setup:
iMac OS X 10.8 – Pure Music v1.89g R3 - iTunes
Hardware setup:
WaveI/O with latest SW (32bit/384 kHz support) – FIFO – Isolator - Dual Clock with Crystek CCHD-957 (LiFePo4 cell powered) – I2S to PCM convertor
DAC setup:
Jumper: short JOB
2* Red Baron V5.0 (NOS TDA1541A) parallel with simultaneous mode
192 kHz file - ok
44.1 kHz file upsamling to 192 kHz - ok
DSD 2.8 MHz file converted to 176.4 kHz - ok
DSD 5.6 MHz file converted to 176.4 kHz - ok
352.8 kHz file - SI570 clock needed
384 kHz file - SI570 clock needed
44.1 kHz upsampling to 384 kHz - SI570 clock needed
DSD 2.8 MHz & 5.6 MHz file converted to 352.8 kHz - SI570 clock needed
@ Ian
Perhaps you could do some upsampling listening tests (44.1 kHz files) between
Dual Clock with Crystek CCHD-957 - 192 kHz and SI570 clock - 384 kHz.
It would be very interesting if the upsamling to 384 kHz would bring the SI570 above the Crystek...
Oliver
Old 15th August 2013, 12:19 AM   #516
iancanada is offline iancanada  Canada
iancanada's Avatar
Software setup:
Hardware setup:
DAC setup:
Jumper: short JOB
192 kHz file - ok
@ Ian
Oliver
Hi Oliver,
Good job! Do you mean you ran your Red Baron 1541A at 384KHz with FIFO KIT and the PCM daughter board? I confirmed 352.8KHz by myself. TDA1541A will be over clocked at both cases according to the spec. It seems Philips engineer left some space there for our audiophiles.
Thank you for the files, I'll upgrade my WaveIO for more test,
Ian
Old 17th August 2013, 07:02 AM   #517
Hi Oliver,
Hi Ian,
with the dual clock board and the 22.5792 MHz and 24.5760 MHz clocks, i have no output with 352.8 kHz & 384 kHz sampling in half speed mode.
I think you need different clock speed. Thats why i wrote SI570 clock needed.
Old 17th August 2013, 07:11 AM   #518
PET240 is offline PET240  Australia
The TDA1541 should accept 176.4 happily as the 7220A/B chip 4 times oversampled with an 11.2896 clock.
So Ian with the half speed mode does that mean the clock is divided by two?
If so with an 11.2896 clock does the TDA1541 require this in half to accept the 352kHz signal?
Old 17th August 2013, 02:51 PM   #519
vzs is offline vzs  Europe
Hi Ian,
Insert an 45.xx and 49.xx in the dual clock board and set it to double-speed mode (read its manual) so you can play 352.8 and 384khz.
zsolt
Old 6th September 2013, 03:15 AM   #520
iancanada's Avatar
zsolt
Yes, for sure they work.
Ian
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver boardHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2549 Today 03:24 PM
FS: Paralleled TDA1541 NOS/OS DAC Board pftrvlr Swap Meet 6 17th April 2011 10:39 PM
AD1865 vs PCM1704 steve jones Digital Source 30 28th December 2008 04:04 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
Urgent sale a lot of NOS (produced in 1996) PCM 63 "K" grade! Altmustech Parts 0 26th August 2006 12:41 PM
Copyright ©1999-2017 diyAudio
