Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Old 12th April 2013, 09:10 AM   #361
vzs is offline vzs  Europe
Last ideas:
- some capacitors seems to be missing around PCM1704 (C39, C41,...) - these seems to be +- decoupling of digital supplies. Are these soldered on bottom-side of the PCB, if not - why do you removed them? To keep your wires on top - try to solder these caps on the bottom-side (watch for polarities)
- is DF1704 powered? without input it's outputs are probably low - being connected to the DACs these might interfere with the other signals. If it's easy (e.g. unsoldering a ferrite-bead) try to un-power DF1704
Old 12th April 2013, 10:37 AM   #362
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by vzs View Post
Last ideas:
The +- psu goes directly to PCM1704 so C39, 41 etc aren't necessary
Nothing more of the obard is powered only the PCM1704
Old 12th April 2013, 10:54 AM   #363
Must read articles about bypass caps roles: "Successful PCB grounding with mixed-signal chips": part 2
Also read part1 and part3.
Even if it goes directly from PSU they should be there, so as a last try, you could try to put them back (to the bottom to leave your wires on top) at least for one DAC.
edit: link corrected
Old 12th April 2013, 11:08 AM   #364
regal is offline regal  United States
Even if it goes directly from PSU they should be there, so as a last try, you could try to solder them back at least for one DAC.
agree, local decoupling isn't a nice too have its a necessity.
With the PCM1704 you will also fid that high vales for the servo decoupling benefit in disabling the stupid BPO, but you need to get 192khz working first correct?
What speed is your master clock ?
Old 12th April 2013, 11:16 AM   #365
Just in case I have put C39, 41.. and same noise mixed with music.
Old 12th April 2013, 11:24 AM   #366
Originally Posted by regal View Post
agre, local decoupling isn't a nice too have its a necessity.
Yes I need to get 192KHz working
WaveIO clocks 22,XXX & 24,XXX
Old 12th April 2013, 11:45 AM   #367
And you are sure your wave I/O setup works at 192khz ?
Old 12th April 2013, 12:03 PM   #368
Yes with BII & BIII using non isolated outputs.
Old 12th April 2013, 01:18 PM   #369
But the BII and BIII have a PLL, my guess is that the 192khz doesn't work on the BIII with the PLL at the lowest setting?
Old 12th April 2013, 01:33 PM   #370
I don't know, now I'm using Amanero with BIII, probably the problem is something that has to see with the clocks or the "timing"" of the BCK?
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver boardHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS: Paralleled TDA1541 NOS/OS DAC Board pftrvlr Swap Meet 6 17th April 2011 09:39 PM
AD1865 vs PCM1704 steve jones Digital Source 30 28th December 2008 03:04 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Urgent sale a lot of NOS (produced in 1996) PCM 63 "K" grade! Altmustech Parts 0 26th August 2006 11:41 AM
