Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Old 26th March 2013, 01:56 AM   #291
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
Any progress lately? Been waiting for the module for a while
Old 6th April 2013, 09:50 AM   #292
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I'm having trouble playing higher than 96K files with my system:
PC->WaveIO->Ian's I2S to PCM converter->PCM1704 DAC.
I have soldered Ian's board output directly to the input pins of the 1704.
When I play 176.4K or 192K I get basically noise with just a little music in the background. 96K and lower play fine.
Any ideas of what might be the problem?
Ian suggested the clocks on the Wave (22.xxx/24.xxx) may be a little on the slow side for the higher sampling rates, can anyone confirm this?
Old 6th April 2013, 06:48 PM   #293
mefistofelez is offline mefistofelez
TOTAL 88
TV Man x 2
merlin el mago
rtd
jameshillj
erin x1 (or 2)
Nikola Krivorov x1
Rupor54
vitalica
analog_sa
andrea_mori x 5
dsavitsk
tagheuer
hirez69 x 2
ccliu x 2
BDL
cddumat
regal x 2
zoran
Jogi
Zen(zenelectro) x 2
Buzzforb
SPWON
crobbins5421 X 2
marcus1 x1 (or 2)
casshan x 2
Dweeb99 X 2
jackw X 2
kazap X 2
danzup x 3
Giordano x2
Tony_T
Tubo x1
clivem x2
noizas x4
JoeyDD x2
skullaudio
dinos8746 x2
dvb-projekt
bisesik x2
guglielmope x1
Valeriano x1
mhgawel x1
av-trouvaille x 1 (or 2)
iloveswan x1
dtses
Flyboi X1
Lil' Knight x1 (or 2)
skippyboy x1
acccruz x1 (or 2)
WhiteBull x1
hksidney x 1
vts2006 x 3
JustBuildLspkAS.x3 &1 fifo kit finished for pcm1704 (ihave AD1862 ,pcm63,pcm1704)
54: PET-240 2 * TDA1541
TonyB
damohpi x1
iloveswan x 1
Joseph K x 2
mefistofelez x2 (pcm63P)
Old 7th April 2013, 09:36 PM   #294
JLOP is offline JLOP  France
+1 for me, thanks
TOTAL 89
TV Man x 2
merlin el mago
rtd
jameshillj
erin x1 (or 2)
Nikola Krivorov x1
Rupor54
vitalica
analog_sa
andrea_mori x 5
dsavitsk
tagheuer
hirez69 x 2
ccliu x 2
BDL
cddumat
regal x 2
zoran
Jogi
Zen(zenelectro) x 2
Buzzforb
SPWON
crobbins5421 X 2
marcus1 x1 (or 2)
casshan x 2
Dweeb99 X 2
jackw X 2
kazap X 2
danzup x 3
Giordano x2
Tony_T
Tubo x1
clivem x2
noizas x4
JoeyDD x2
skullaudio
dinos8746 x2
dvb-projekt
bisesik x2
guglielmope x1
Valeriano x1
mhgawel x1
iloveswan x1
dtses
Flyboi X1
skippyboy x1
acccruz x1 (or 2)
WhiteBull x1
hksidney x 1
vts2006 x 3
TonyB
damohpi x1
iloveswan x 1
Joseph K x 2
JLOP x1 (WaveIO, AD1865 NOS SRPP)
Old 8th April 2013, 01:07 AM   #295
iancanada is online now iancanada  Canada
iancanada's Avatar
Hi merlin el mago,
I'm gonna test it again at same case by a logic analyzer. A picture of your setup and system would be help.
Ian
Old 8th April 2013, 08:47 AM   #296
Hi Ian,
As requested attached several pics
TIA
Felipe
Old 8th April 2013, 10:07 AM   #297
vzs is offline vzs  Europe
IMO you have some serious signal integrity issues - it's a miracle it works at all.
The re-clock FF on the I2S to PCM board is fast (maybe too fast?) - Potato logic - it has very fast rise times and this seems to require great care. I would even use the PH2.0 output only for testing and change to u-fl for the final setup.
As a last try - before making a small adapter board - I would try to run ground wires twisted near all lines not only the data line.
If you seriously want to use this PCM1704 evaluation board I would make a small adapter in your place - something similar to the attached sketch (excuse my Paint skills)
edit: same issue between WaveIO-I2S-to-PCM (good question how to connect them correctly) maybe remove the 7pin PH2.0 from the converter input and try solder u-fl connectors
Old 8th April 2013, 10:15 AM   #298
Do you refer to twist with gnd LLLR & CLK wires?
Old 8th April 2013, 10:17 AM   #299
Yes... but please consider the adapter board. Also see later-edit note about input connector.
Old 8th April 2013, 10:23 AM   #300
Do you know where can I buy the adapter board with U.FL connectors?
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver boardHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS: Paralleled TDA1541 NOS/OS DAC Board pftrvlr Swap Meet 6 17th April 2011 09:39 PM
AD1865 vs PCM1704 steve jones Digital Source 30 28th December 2008 03:04 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Urgent sale a lot of NOS (produced in 1996) PCM 63 "K" grade! Altmustech Parts 0 26th August 2006 11:41 AM
