Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
Old 1st January 2013, 07:35 AM   #171
erin is offline erin  Australia
Location: http://www.acmuller.net/con-dao/daodejing.html
http://www.intersil.com/content/dam/...n96/an9657.pdf
Old 1st January 2013, 09:14 PM   #172
Giordano is offline Giordano  Hungary
Hello,
I was playing with the raspberry pi for a day, now I have a remote controlled (by and android tablet) media player, with BAD sound output. Now I need a USB to I2S adapter. Which one do you suggest ? It should work with the standard libraries, with not special driver. Smaller is better. Than I will need this board between the I2S and my AD1865 DAC.
Thanks,
JG
Old 2nd January 2013, 02:41 AM   #173
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by erin View Post
The L/R simultaneous mode is probably the most desirable way to use your board with the TDA1541. Very few TDA1541 designs use offset binary because of the complexity of the glue logic required to do this.
I have never tried it, but my understanding is that offset binary is the same as two's compliment, just with the MSB inverted.
These two links seems to explain it well.
C3Dformat
Offset binary - Wikipedia, the free encyclopedia
I will be interested to try offset binary with the TDA1541 this when the boards are finally ready.
Thanks erin,
In this case, it seems I need to include the offset binary decoding into my FPGA design for TDA1541/A. Hopefully, we still can get drop of juice from it.
Ian
Old 2nd January 2013, 03:41 AM   #174
new2hifi is offline new2hifi  United States
Default Oversampling/NOS
Originally Posted by ryanj View Post
Hi Ian,
...........With the I2S to PCM convertor board you get the added "advantage" of oversampling of up to 8x (352.8k).........
Ryan
So this I2S to PCM convertor cannot be used in pure NOS application due to oversampling? Oversampling is a forced operation or could be turned off?
Old 2nd January 2013, 05:09 AM   #175
ryanj is offline ryanj  Australia
EE Hack
ryanj's Avatar
Hi new2hifi,
Since the TDA1541A accepts the I2S format directly, there is no point converting from I2S to PCM if you want to run the 1541 in NOS.
I really don't know enough about the PCM format to comment on any advantages. Maybe somebody else can advise.
Ryan
Old 2nd January 2013, 06:46 AM   #176
qusp is offline qusp  Australia
qusp's Avatar
can a synchronous oversampled 4-8*FS output from this board be fed directly to the TDA for DEM reclocking, or is the only way to adjust the DEM by the use of specific capacitor values to adjust the normally free-running clock?
Old 2nd January 2013, 11:11 AM   #177
Originally Posted by iancanada View Post
Thanks erin,
Ian
Yes that would be very good of you to do so.
Old 2nd January 2013, 11:15 AM   #178
Hi new2hifi,
Ryan
Please allow me to advise.
This board Ian is making will allow the option of a simultaneous output of offset binary Left and Right Data. For TDA1541 enthusiasts, and tinkerers, this will allow a person to create a dual mono TDA1541 board. Also possible is a dual differential, or balanced output TDA1541 board.
I know many people will be interested in these possibilities.
And it may be worth nothing, but I have read reports from those that have tried it, that the offset binary data input sounds better than the i2s.
I don't know, but I am keen to try it.
It will also allow the use of the TDA1540 chip.
Old 2nd January 2013, 11:26 AM   #179
EE Hack
ryanj's Avatar
Qusp, the 1541 has limited bandwidth to about 6.5Mhz. The DEM has successfully been clocked from BCK at 2.8Mhz by several members following such designs as member "ecdesigns" (John Brown) has used in the past.
Old 2nd January 2013, 11:27 AM   #180
EE Hack
ryanj's Avatar
Thanks for clearing that up erin.
Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver boardHide this!Advertise here!
Ian asynchronous I2S and S/PDIF FIFO KIT group buy iancanada Group Buys 2595 4th May 2018 04:20 PM
FS: Paralleled TDA1541 NOS/OS DAC Board pftrvlr Swap Meet 6 17th April 2011 09:39 PM
AD1865 vs PCM1704 steve jones Digital Source 30 28th December 2008 03:04 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
Urgent sale a lot of NOS (produced in 1996) PCM 63 "K" grade! Altmustech Parts 0 26th August 2006 11:41 AM
