| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi all,I know from past posts and my own trail & error tests that solid core copper cable gives much better results & a better tonal balance with low distortion.
Silver cables seem brighter & if you listen to them with good amp and cans you can realy hear the distortion and muddled sound. So is the same then true for coaxil cable too? I'm thinking yes but I have not tried it myself and wondered if anybody has tried different coaxil cables including solid core copper and silver? Also I am considering building my own coaxil cable using 2 lengths of belden 1694A coaxial cable and just use the internal solid core conductors for the input & return paths like the chord company signiture digital construction. Comments and advice much appretiated |
#2 |
Digital signals are best transmitted with the signal and return in very close and intimate proximity, so from a signal integrity point of view either a standard co-axial or a shielded twisted pair, matched to the required or recomended signals impdance (50 ohm usually for digital.)
Digital transmission down a cable is digiatl transmission, silver or solid core are not important, impedance matching and a good close proximity to return current paths are. The chord cable is not a good example of a digitalk transmission cable. |
#3 |
It is almost impossible for the home constructor to make good coaxial cable, and there is no valid reason why anybody would want to. Even manufacturers struggle to maintain the required geometry, which is one reason why decent coax costs more than cheap stuff. It is one of those areas of DIY in which those who know enough to do it properly also know enough to not attempt it.
If you really want to make your own digital cable then twisted pair is much easier. Even then you will need the right test equipment to ensure that it maintains 75ohm characteristic impedance all the way along, and you will need baluns at each end to interface to the normal unbalanced equipment ports. Good luck! |
| Audio coaxial cable for guitar | akis | Instruments and Amps | 3 | 22nd August 2009 05:02 PM |
| coaxial loudspeaker cable ??? | montana | Multi-Way | 1 | 11th April 2008 03:44 PM |
| Coaxial Cable Capacitance | -_nando-_ | Parts | 2 | 17th March 2007 04:13 PM |
| microphone cable vs coaxial cable | Leolabs | Parts | 4 | 31st August 2006 10:24 AM |
| diy coaxial audio cable | rnzr | Digital Source | 30 | 4th February 2005 10:23 PM |
