Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st September 2012, 05:41 PM   #1
Default DCX2496 Problem: no "SUM" output to subwoofer
Any help would be most appreciated to solve this problem.
Software Version 1.17.
Problem: no "SUM" output to subwoofer in the Stereo Two-Way Operation Plus Subwoofer configuration.
I have the crossover exactly configured as in figure 6.2: stereo two-way operation plus subwoofer as on page 23 of the users manual.
Input signal: Digital.
Though in this configuration the SUM of the bass frequencies in A + B should go to output 5, I find that in output 5, if I select SUM I don't get any bass frequencies at all. If I select B, I get the bass from channel B only.
I think this must be a software fault as in my users manual on page 23, the Routing shows the bass signals from A and B going into a SUM box and the output from this box going to output 5, but on my crossover the Routing shows only the bass frequencies from channel B going to output 5. So to me it seems impossible to get the SUM mix of A + B because the software won't allow it.
Has anybody else got this problem? Or have you got this figuration working properly.
I have already tried a factory reset but though the reset worked properly it did not fix the problem.
Problem solved.
In the end it was very easy to resolve this problem by downloading the remote control software from Behringer which allows one to adjust all the parameters and is very easy to use.
Last edited by cirrus18; 26th September 2012 at 10:55 AM. Reason: Problem resolved
Old 21st September 2012, 05:44 PM   #2
jan.didden's Avatar
Did you try with different music? You may have just gotten a piece with only bass in channel B.
Happened to me one time.
jan
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 21st September 2012, 06:42 PM   #3
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by SY View Post
What's wrong with the DACs? They are far and away not the weak point which is why people have been concentrating on the things which are. #1 is the output analog electronics. #2 is the input analog electronics. #3 is the digital receiver. #4 is the clock.
Take care of 1 and 2 and you're 99% of the way there.
That's my priority list as well... plus PS noise reduction. -RNM
Old 21st September 2012, 07:20 PM   #4
jan
It happens with all music.
Old 21st September 2012, 07:54 PM   #5
Pano is offline Pano  United States
Pano's Avatar
Merged from other thread. It is against the rules to duplicate posts in various threads. Please read the rules.
Don't you have to choose the source of SUM? I can't remember, but will look when I get home.
Old 22nd September 2012, 01:25 PM   #6
thanks for your help but as far as I can see there is no way of selecting the source of SUM. It seems that it is selected automatically in this configuration.
DCX2496 "extra" settings to improve XO designed with it? doug20 Digital Line Level 4 4th May 2010 04:58 PM
To sell: one Polk 12" "metallized" subwoofer kencogan Swap Meet 0 16th January 2010 02:21 PM
Subwoofer with 10" High Output Buyout 69stingray Subwoofers 7 6th August 2007 11:59 PM
Any DCX2496 "off-the-shelf" mods available? pkpickard Digital Line Level 1 12th February 2006 11:57 PM
"lift off " or "Houston we have a problem" tenderland Tubes / Valves 16 1st May 2005 05:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
