Go Back   Home > Forums > Source & Line > Digital Line Level
Old 22nd November 2012, 07:35 PM   #31
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Is this available?
I'd like to use this along with my amanero.
Old 23rd November 2012, 03:46 PM   #32
I have a small stack of PCBs available.
But I do not really have a BOM or to be more precise I know the sizes(housing) and values of the components used but I do not have a complete BOM with part numbers available.
So anyone buying PCBs would have to do some work on their own.
But in general, use metalfilm resistors - 5% is more than good enough, X5R/X7R ceramic capacitors, except the output filter where I used PPS film capacitors.
Old 23rd November 2012, 07:07 PM   #33
I am thinking about making a simple add on USB module based on PCM2707C.
It would be limited to 16 bit/48 kHz but to be honest, I do not have anything above 16 bit/44.1 kHz and I really do not expect to get any material with higher bit and sample rates than that in the near future. I basically only listen to my CD collection ripped and compressed in FLAC.
It would connect directly to the I2S input male header on the DAC board through a female header mounted on the bottom of the USB to I2S board.
Old 23rd November 2012, 10:11 PM   #34
Or I could just go with the Amanero USB I2S board, looks like it is a great little board with support for more or less everything and at 39 EUR it is cheap.
Or just stay with my Ebay TE7022L board.
Decisions, decisions.
Old 24th November 2012, 09:16 AM   #35
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
Amanero, 2707 is more than just limited in speed, its just flat out limited full-stop and a big part of why USB audio initially had a bad name
Old 24th November 2012, 12:10 PM   #36
You are probably right.
I am most likely going with the Amanero board, it is just too great a value.
Old 24th November 2012, 12:18 PM   #37
qusp's Avatar
indeed cant argue with the price that we managed to secure here with the GB, not a bad little board either. it does need a bit more filtering for the PSU (or replace it entirely since it has that option) otherwise it can let some noise through on the USB lines.
check out glt's blog, some of the execution is a bit rough, but there is some good commentary there on the amanero board and USB audio in general
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
ALPS RK27 100KBX2 POT tommy54 Swap Meet 1 30th January 2012 01:04 AM
ALPS POT RK09 RK168 RK27 tommy54 Swap Meet 5 5th November 2011 01:42 PM
ALPS RK27 50KAX2 POT tommy54 Swap Meet 4 11th August 2011 08:11 PM
FS: Alps RK27 motorised volume pot with remote controller PCB ready to fit in amp rabbitz Swap Meet 3 8th September 2004 03:09 PM
Copyright ©1999-2013 diyAudio
