Behringer DEQ2496 - Digital Out - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th September 2012, 04:11 AM   #1
Banned
Default Behringer DEQ2496 - Digital Out
I am having an issue using the digital-out of the DEQ2496 into an external DAC.
I am losing about half a second at the start of each song. It is annoying the hell out of me.
I have tried both optical, and AES/EBU (xlr), and the issue is the same.
Not sure how to fix the problem.
Anyone have ideas
Old 16th September 2012, 04:21 AM   #2
Pano is offline Pano  United States
Pano's Avatar
I remember seeing that problem a few years back with a DAC that I can't remember the name of. The DAC would mute at the loss of the digital signal. It didn't unmute fast enough when the signal came back.
My DEQ has no problem with this at all on the analog outs. Can't say for certain on the digital out. Do you have a way to check if the DEQ is dropping the steam between songs?
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 16th September 2012, 04:30 AM   #3
Banned
I don't have a problem with the analog out, just the digital out is causing the problem
Old 16th September 2012, 04:40 AM   #4
Pano's Avatar
Yes, I understand. You need some way of checking the digital output to see if it's dropping between songs.
Does it do this will all digital sources?
Old 16th September 2012, 04:41 AM   #5
Banned
It looks like it is only happening on flac files recorded to a DVD disc not regular cd recordings.
The issue does not occur with analog-out on the behringer though
I will check a few more cds
Old 16th September 2012, 04:44 AM   #6
Pano's Avatar
Strange. Can you hear mute relays in the DAC? I did when I had the problem.
Old 16th September 2012, 04:50 AM   #7
Remlab is offline Remlab  United States
An SRC (Digital data reclocker and upsampler)placed after the DEQ should solve your problem. It will probably sound better too.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 16th September 2012, 05:16 AM   #8
Banned
There is no continuous lag it is just at the start of each track.
I have connected one channel with analog out from the behringer the other channel digital out into an external dac, and it is about half a second lost at the start of a FLAC file. It's not an issue if the file does not start at 0 seconds but if it does I lose about half a second
I am still checking more cds
Old 16th September 2012, 05:35 AM   #9
Banned
You can also hear a slight pop when the signal comes in, like a relay making contact
Old 16th September 2012, 06:40 AM   #10
Banned
Not sure if the issue is with the behringer digital out or the DAC (emotiva xda-1)
Modify behringer DEQ2496? Rapid Digital Line Level 241 7th March 2017 11:30 AM
Integrating the Behringer DEQ2496 AstralFurious Digital Line Level 1 19th December 2011 09:11 AM
FS: Behringer DEQ2496 Ultracurve Digital EQ matevana Swap Meet 2 23rd December 2010 11:30 AM
FS:Behringer DEQ2496 Ryssen Swap Meet 15 16th April 2009 08:24 PM
Behringer DEQ2496 into T Amp? joesan Digital Source 7 19th October 2005 10:30 AM
Copyright 1999-2017 diyAudio
