Hifimediy ES9023+TE7022 24/96 USB Dac - Page 36 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th September 2013, 02:25 PM   #351
Originally Posted by Sugar Man View Post
That was weird. Here is another one http://www.ebay.com/itm/200948481228?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1438.l2649 Maybe link will work this time or search on ebay - tag: ES9023 XMOS
I know about U2 and thank You for impression. But I just think about the DAC from ebay as an alternative in metal case. But I do not know will it be as good as U2 and will there be any problems with it (drivers, USB power, ect )?
I have read previous posts about USB isolator. But maybe I need one more simply confirmation I do not want buy more expensive isolator because I looking for simply and low cost solusion. If Hifimediy USB isolaor not good enough then I just give up this idea.
Thank You for your opinions
The new link works. It looks like an impressive product with the XMOS processor, case, and price point. I hope someone here has one or buys one and can give their impressions as I am interested also. As regards the USB isolator and SQ, it really depends on how you are using your DAC. If you are using it with a desktop or laptop using an AC power supply, then the isolator might clean up the data signal as it separates power and data. You can run your laptop off the battery and possibly eliminate that issue. I mainly use mine for a portable headphone rig using my smartphone via USB out. I used the Teralink isolator to power the DAC with its own battery rather than drain the phones battery. My personal opinion regarding whether the XMOS DAC would sound better than your UAE23 really depends on where you are sending that signal. High end amps,speakers, headphones may reveal an improvement, mid to lower end probably not. satwilson
Last edited by satwilson; 6th September 2013 at 02:42 PM. Reason: link not working again in forum, worked in the email subscription sent to me, moderator? r
Old 19th September 2013, 12:03 AM   #352
tofurky is offline tofurky  United States
Default reverse polarity - oops
hi,
i had a duh moment the other day with this & my adum4160 isolator board.
in the process of trying to troubleshoot some EMI issues with my usb setup, i switched out the 5v regulator powering the dac+adum4160 with another, almost identical one. almost, except i had wired the terminals differently
the dac was hooked up with the polarity backwards for maybe 60s or so until i realized something was amiss.
testing the dac with rmaa showed nearly identical (and in one instance, a "perfect" 96db snr with 44.1/16) results. but i'm still concerned.
the dac uses an lt1763 regulator with reverse battery protection, and the es9023/te7022l behind it. there are 3 os-con capacitors on the board though, and i'm not sure if any of them are in front of the lt1763? i didn't see any bulging or that sort of thing when i pried the dac open to inspect.
should i be concerned about damage? would the reverse battery protection prevent capacitors behind the regulator from picking up a reverse charge? or would some small current still flow backwards through the regulator?
thanks,
-matt
Old 19th September 2013, 05:21 AM   #353
McDark is offline McDark  Russian Federation
Send a message via ICQ to McDark
Do not worry Matt, reg will completely shut off its output when reversed. Properly designed board will also protect input caps if any (there is usually protection diode on input, you could look for it).
Yuri
Old 27th September 2013, 01:31 AM   #354
Default hifimediy U2-async
I ordered the async version of uae23 and just received it. I think it sounds fine but i want to know the RMAA measuremts on this toy. I wish I could measure it by myself but I'm afraid I don't have any devices for that. I'll be forever grateful if someone could post it.
Old 27th September 2013, 01:13 PM   #355
Send a message via Yahoo to linuxguru
Originally Posted by enjoybiking View Post
If you can solder SMD then try 100K-130K ? 0603 ? SMD R on the vacant pins on the the PCB that go to ES9023 pin#6 to GND. I used 100K, love it!!
Thanks for the tip - I have the following mods on a UAE23 v1.1, and it certainly seems to tame the harshness that some people observe:
1. 120k to ground on R3.
2. C8 changed from 10uF/10V Oscon to 220uF/4V Black Gate PK (this is the LT1763 3.6V regulator output bypass).
3. C9 changed from 10uF/10V Oscon to 4.7uF/50V Black Gate PK (this is the bypass on Pin 6 of ES9023).
4. Added 4.7uF/50V Black Gate PK directly soldered on Pin 11 (NEG) to pin 14 (DGND) of ES9023. It's too difficult to solder it on adjacent pins 11 & 12 (AGND), so I used pin 14 instead - it's grounded at the same ground plane as pin 12, just a few mm away. Pay attention to polarity - the negative terminal of the capacitor goes to Pin 11.
5. Bypassed C10 and C11 (both 1uF) on the underside with 0805 47nF/50V X7R. Not really necessary if both C10 and C11 are X7R, but just insurance in case they're Y5V or similar. There may be some benefit in using SMD PPS caps like Panasonic ECHU to bypass these, but they tend to be larger, typically 1206 or more in useful values like 47 nF and 100 nF, so I stayed with X7R.
6. Changed C13 and C14 from 6.8nF Wima FKP2 to 5.6nF/63V ERO KP1837. Not really necessary IMHO - but some on the Subbu DAC and other threads have recommended lowering it to 4.7nF or even lower. 5.6nF is a reasonable compromise which sounds fine.
Overall, the mods get rid of most of the harshness/brittleness without losing micro-detail. There's also more air and cohesiveness, and it's now good enough to be my primary reference DAC.
Old 3rd October 2013, 01:23 PM   #356
The modded UAE23 was auditioned yesterday in a fairly serious audiophile setup, driving a Dared VP-845 integated SET tube amp, driving a pair of Cadence Arista floorstanders with electrostatic tweeters. I used Rhythmbox on a notebook to play .flac and .m4a hi-res as well as CD-quality 16/44.1 tracks through the UAE23. The other DACs in the fray were an ODAC (also ES9023-based), a tube-buffered TDA1541A DAC, and a Feixiang FX-98s PCM2704 DAC.
On the CD-quality tracks, the tube-buffered TDA1541A held its own. However, on any of the 24/96 tracks, both the ES9023-based DACs (the UAE23 and the ODAC) easily trumped the others on dynamics, headroom, detail, separation, sound-stage - practically any audible yardstick.
Overall, the modded UAE23 was darker and smoother than the stock ODAC, but the ODAC had a bit more micro-detail and air. I preferred the modded UAE23 on overall presentation as well as (possibly) lower fatigue, as compared to the stock ODAC, but individual tastes may vary.
Old 6th October 2013, 09:29 PM   #357
I'm hoping someone could offer subjective opinions on the new UE23 with the SA9023 receiver vs the old Tenor TE7022 chip. I'm about to pull the trigger on one of these DACs, but was wondering what the audible differences were between the two USB chips. I know the specs on the SA9023 allow for 88khz whereas the 7022 does not...but I'm wondering if the new USB chip implementation has any impact on the sound of the DAC since both are still available.
Has anyone directly compared the new version (sa9023) to the old UAE23 (te7022) in terms of sonic signatures/SQ?
Old 7th October 2013, 06:42 AM   #358
uncola is offline uncola  United States
I used to have the old tenor based one but gave it to a friend.. I have one of the new savitech ones coming.. I didn't know there was an asynchronous version available when ordering so now I wish I had gotten the asynch one
Old 7th October 2013, 12:28 PM   #359
Would you be so kind as to offer a subjective comparison between the two when it arrives? Also, let me know if you would like to sell it if you decide to get the a-sync version
Old 7th October 2013, 03:34 PM   #360
I purchased both versions thinking the asynch and 88khz as a reasonable upgrade given the modest cost involved. My impression was the SA9023 was somewhat smoother or warmer but still retaining the upper frequency detail. This was not an in depth comparison and involved my Android phone, USB out to the DAC, to an amp and Fostex T50RP orthodynamic headphones. The files were FLAC, some 96khz HDTracks downloads. I wish my soldering skills were up to SMD devices as I would like to modify one like others have done in previous posts. IMHO the SA9023 is the one I prefer. Hope this helps, satwilson
TE7022+ES9023 mini toy^_^ hifimediy PC Based 23 1st March 2013 07:20 AM
New 24/96 usb converters sendler PC Based 0 7th October 2010 10:10 AM
USB to SPDIF that does 24/96 and works in linux morfic Digital Line Level 0 26th June 2009 11:04 PM
Musiland Lilo 3 - 24/96 USB to SPDIF? Kane Williams Digital Source 15 21st August 2008 12:14 PM
m-audio "transit" usb 24/96 dac and digital i/o Mark Hathaway Digital Source 2 9th January 2005 05:13 PM
Copyright 1999-2017 diyAudio
