Hifimediy ES9023+TE7022 24/96 USB Dac
Old 1st July 2013, 05:37 AM   #311
cristi289 is offline cristi289  Romania
cristi289's Avatar
Send a message via Yahoo to cristi289
Originally Posted by Roman M View Post
In UAE23+ I unsoldered resistor in MCLK line. On pins 13 and 14 ES9023 are soldered XO Golledge 50 MHz. Sound is much improved, better bass, better dynamics, better 3D image, better transparency. Recommended.
Ok, I do that modification and you are right - the sound is much improved. One mention, I powered the "clock" from an stabilizer LM1117-5. Sun I will get in possession of their power supply unit ( Power supply for SABRE DAC 2 (UAE23+) 200-240V ), and maybe with that I will obtain again an improvement ...
Best regards,
Cristi.
Old 4th July 2013, 07:35 AM   #312
16tons is offline 16tons  Italy
hello everyone, i've a grado sr80 since few days that i use with laptop and sansa clip zip, i would to add a dac/amp and i've considered to combine the hifimediy UAE23 with a little dotI+ that seems to be an optimal ampli for grado headphones Little Dot Amplifiers • View topic - Little Dot I+ Hybrid Headphone Amplifier
linking them witha a jack to rca cable. is this a good choice? i must consider the ua23+ too?
Old 4th July 2013, 08:14 AM   #313
nimo is offline nimo
16tons,
Ihave play FLAC from my laptop and use the SR-80i as well.
1) I added the UAE23: The DAC Awakening ? HifiMeDiy UAE23 (Part 2) - nimophile
2) next, I added the Little Dot 1+: HeadAmping - Little Dot 1+ [Hybrid Headphone Amplifier] (Part 1) - nimophile
3) and then, swap some op-amps and tubes: Op-Amping ? Little Dot 1+ [Hybrid Headphone Amplifier] (Part 2) - nimophile
My PC Audio setup is on the last link. Hope this helps.
Old 4th July 2013, 10:03 AM   #314
very useful thank you very much, any issues with win 7 64bit? is this cable good? 3.5mm Mini Jack Stereo to 2 RCA Phono Cable OFC GOLD 0.5M Short Audio Cable 50cm | eBay
Old 4th July 2013, 10:34 AM   #315
No issues whatsoever. I'm on Win 7 Pro, 64-bit. No drivers needed. Simply plug n' play. Windows will install native drivers.
Sent from my Nexus 4 using Tapatalk 2
Old 4th July 2013, 10:49 AM   #316
Cable looks fine I guess. I run a 0.5m into the LD1+ from the UAE23 too.
Old 4th July 2013, 06:50 PM   #317
could you tell me if the line out of the dac is gold/metallic? i found one used but as you can see in this image has the line out totally in plastic ImageShack® - Online Photo and Video Hosting
Old 9th July 2013, 03:34 PM   #318
i've asked directly to hifimediy, it's a model uae23r with optical input
Old 21st July 2013, 07:26 AM   #319
hollowman is offline hollowman  United States
hollowman's Avatar
Other than ODAC ($150), anyone compare the HifiMeDiy Sabre USB DAC to other similar devices such as:
AQ DragonFly($250)
... or the newer ...
HRT microStreamer? ($180)
BTW (and correct me if I'm wrong, of course) ... on this TYPE of device, I don't see much "pure" DIY activity here our forum or other DIY communities (nope ... naked PCB kits and stuffed eBay PCBs from China don't count!). Could it be that at the low $$ these devices are now avail. -- plus the difficulty of SMT/SOP sizes, and economies of scale -- pretty much rule out these USB's in anything other than Eagle-only amusements?
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 21st July 2013, 07:49 AM   #320
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Seems like the chance to show us what you designed and built.
It's only audio. Member of the non modular PCB design committee
Hifimediy ES9023+TE7022 24/96 USB DacHide this!Advertise here!
TE7022+ES9023 mini toy^_^ hifimediy PC Based 23 1st March 2013 07:20 AM
New 24/96 usb converters sendler PC Based 0 7th October 2010 10:10 AM
USB to SPDIF that does 24/96 and works in linux morfic Digital Line Level 0 26th June 2009 11:04 PM
Musiland Lilo 3 - 24/96 USB to SPDIF? Kane Williams Digital Source 15 21st August 2008 12:14 PM
m-audio "transit" usb 24/96 dac and digital i/o Mark Hathaway Digital Source 2 9th January 2005 05:13 PM
