Hifimediy ES9023+TE7022 24/96 USB Dac
Old 20th September 2012, 01:09 PM   #21
alkasar is offline alkasar  France
sorry to repeat my question : how did you get a Sabre driver ?
when i install hifimediy's dac on windows seven, the usb audio microsoft driver is used.
Old 20th September 2012, 02:34 PM   #22
nakamoomin is offline nakamoomin  Norway
When I put it in my USB port it automatically installed the drivers called
"SABRE 24/94 DAC"
In the advanced settings I can see that it is basically the same as the "ODAC" driver:
Microsoft
USBAudio
(Generic USB Audio)
wdma_usb.inf
6.1.7601.17514
Both devices lists these drivers:
- drmk.sys
- ksthunk.sys
- portcls.sys
- USBAUDIO.sys
- SysFxUI.dll
- WMALFXGFXDSP.dll
Sabre 24/96 has these panes in the PROPERTIES section:
General - Supported Formats - Levels - Advanced
ODAC has these panes in the PROPERTIES section:
General - Enhancements - Levels - Advanced
Under "supported formats" one can chose which formats the DAC supports:
- DTS Audio
- Dolby Digital
- Microsoft WMA Pro Audio
and samplerates:
- 32.0 kHz
- 44.1 kHz
- 48.0 kHz
- 96.0 kHz
These are check-boxes, and multiple boxes may be checked.
This differs from the "Enhancements" pane that is shown under the ODAC device which lets you adjust bass level, room correction etc.
I'm running Win7 Corp, 64-bit.
Old 20th September 2012, 03:01 PM   #23
wwenze is offline wwenze  Singapore
Same receiver IC, same driver, external rom containing different USB descriptor, having a different name in Device Manager is possible.
Not so sure about the features that Windows reports it to have, but well since you've seen it happen...
Old 20th September 2012, 05:09 PM   #24
Yep, that is what I think. The windows driver is the same but it runs in different modes if you like..
What worries me is that it can't be good to run two instances of the same driver at once. I believe that I had both ODAC and HifiMeDiy connected at the same time.. This could have affected the review.
Listened to them today, but one at a time and no switching back-and-forth all the time. They both sound good but there is still some issues at the top. The very short usb cable of the HifiMeDiy DAC could be an issue.
A: no ferrite bead
B: very close to the laptop which is putting out a lot of RF noise (HDD, WiFi, CPU, etc)
The HifiMeDiy is also housed in a plastic box which offers no protection from RF... Placed 5 cm from the noise machine that is my laptop.. Not ideal.
Old 20th September 2012, 05:16 PM   #25
glt is offline glt  United States
A: no ferrite bead
Thanks for comparing and sharing the results!. The comparison with ODAC is most interesting...
www.hifiduino.wordpress.com
Old 20th September 2012, 06:39 PM   #26
Ah ok, got it. I was confused when you mentioned different drivers.
TE7022E has a built in ROM for USB descriptor. Vendors can set a manufacturer's name, specific device name and declare the device supported features for windows. Hence some tabs are visible or not, depending on descriptor.
The "enhancements" tab is not from Sabre, but from microsoft. You don't want to use that crap anyway. Better rely on a player like foobar and use high quality DSP plugins if you need to enhance the sound
you can try adding a ferite beam to the hifimediy ?
1P TDK 5mm Clip-on RFI EMI RF Radio Audio Video Cable Noise Filter Ferrite Core | eBay
$1.31, incl shipping !
Old 25th September 2012, 07:27 PM   #27
na is offline na  Finland
I have used this sometime now and i must say the sound in my opinion is pretty neutral, and it digs the details what is in the record..
Do i like it?
For the price it is good but i like the sound of Wolfson (8741) more (my earlier dac) with my headphones.
Wolfson fatter sound suits better for me
I now have ATH M-50 headphones and problem is (if hp are driven directly) that it is too loud even if i try custom settings with my Macbook + VLC player..
So i think it can drive many headphones directly.
For the price its thumbs up!
Old 25th September 2012, 07:39 PM   #28
Replaced the cable with a 1m shielded USB cable from a printer. Ferrite beads at both ends.
Not sure if this improved the top. I will get a aluminium case for the DAC and maybe put a propper filter on the shield (RC). Could also be an idea to put some small film cap (100nF) on the power...
Still a little harsher on S'es and hihats than the ODAC, but all in all a very good DAC considering the money. I'll probably not use this with my headphone rig, as it is a bit fatiguing in the long run. However, for my office setup or with a nice, warm full range which rolls off the top a bit: This would be a great bang for buck DAC.
Old 25th September 2012, 10:42 PM   #29
agdr is offline agdr  United States
agdr's Avatar
I asked HiFimeDIY about that right after I ordered (still in the mail) since I knew I would have that issue with my AKG K550s. The DAC product page says a single resistor can change output level. HiFimeDIY says try soldering a 100k resistor across C9 to lower the output.
Old 26th September 2012, 11:37 AM   #30
azimut is offline azimut  Italy
Originally Posted by jean-paul View Post
Gets its power from the USB bus and it has a noisy reg....when you change that it could be a very good DAC but then it is not cheap anymore.
It looks like new batch use a different reg (LT 1763).
What reg they use before?
WOW!
It doesn't have quite the same neutrality and airy resolution as the ODAC, but for 39 USD I'd say it's very close, certainly more than I expected. A very entertaining DAC indeed.
Price wise is excellent!
It would be interesting to see some measurements...devils is in details. NwAvGuy said that despite following the reference design, the first version of the ODAC only had about 98 dB DNR, getting much better than 16 bit (96 dB) performance can be challenging (ODAC after different release has 111 db DNR)
Hifimediy ES9023+TE7022 24/96 USB DacHide this!Advertise here!
TE7022+ES9023 mini toy^_^ hifimediy PC Based 23 1st March 2013 07:20 AM
New 24/96 usb converters sendler PC Based 0 7th October 2010 10:10 AM
USB to SPDIF that does 24/96 and works in linux morfic Digital Line Level 0 26th June 2009 11:04 PM
Musiland Lilo 3 - 24/96 USB to SPDIF? Kane Williams Digital Source 15 21st August 2008 12:14 PM
m-audio "transit" usb 24/96 dac and digital i/o Mark Hathaway Digital Source 2 9th January 2005 05:13 PM
