Hifimediy ES9023+TE7022 24/96 USB Dac
Old 28th February 2013, 08:55 AM   #271
KlipschKid is offline KlipschKid
Originally Posted by soundcheck View Post
Though I'm not sure if the ADUM isolator of the DAC 2 -- which seems to be doing quite a good job -- would still work with the CM6631A.
Cheers
ADUM4160 can work with the CM6631 (plug device into iso, switch on iso, plug iso into PC) but it switches the driver into a slower speed so the device becomes limited to 96/24. I haven't managed to get it to work with CM6631A. (31A supports 176.4 but non_A doesn't)
Old 5th March 2013, 06:36 AM   #272
kroyin is offline kroyin  India
Default Volume issues
Did anyone have volume problem with the USB variant.
Plug n play on Linux (alsa+mpd) works well but plays a lot less loud than my wm8741 dac
Asus Netbook (ALSA+MPD)->EBay 4xWM8741 DAC->DIY DCB1 preamp with Optical Volume Control ->DIY F5T V2-> DIY 2.5 way Peerless Nomex by Troels Gravesen
Old 7th March 2013, 12:39 AM   #273
Nanoloop is offline Nanoloop  Hong Kong
Maybe you can try an op amp on the output for small gain. AD8397 can drive headphones directly.
Old 7th March 2013, 01:43 AM   #274
My mistake, forgot the alsamixer part where you set the volume for the device.
All is well now
Old 22nd March 2013, 04:42 PM   #275
diyricky is offline diyricky  United Kingdom
Hi All,
Just a novice to DACs and had been looking at the various ebay cheapies and some lower end Fiio ones, though most of their models need an extra RCA/line adaptor.
Now found a link to this thread and the UAE23, which description was a bit confusing as it says Usb to Optical, though its seems the output connector is a jack that can be used as a line output at 2v - correct ?
Having read though all 28 pages of this thread it seems the UAE23+ model is perhaps the better model ?
Seems the advantages of the + are the volume control, RCA output sockets, isolation and external psu.
Wondered if you all agree the 23+ is the better option for a desktop system ?
Although not mentioned expect many of you are also now on W8 so wondered if there were and driver problems there ?
I'm looking to connect to an Arcam amplifier but it needs a 5 meter cable, so wondered what is the best way to do that, a long USB cable, long interconnect or 50/50 ?
Finally one for the EU guys, notice the HifimeDIY says they can post out from Belgium, but could not see any option to select in the checkout area, do they automatically send small orders out via the Belgium route ?
thanks
Old 23rd March 2013, 10:40 AM   #276
Cornelis Spronk is offline Cornelis Spronk  United Kingdom
If only for desktop use, I would choose the UA23+. It is better for future tweaking if so desired.
The output is at a low impedance, so a long interconnect for the audio will not make any noticable difference. But then, this is DIY. Try either way and let us know your results.
For portable laptop use, the UA23 is so convenient. In fact, I would have both, as the price is so small.
I have ordered a second UA23 to the UK a couple of months ago directly from Hfimediy. It was first shipped to Switzerland, then to the UK. Hfimediy choose this route.
Just the facts! State your evidence.
Old 23rd March 2013, 11:37 AM   #277
Thanks for the reply, looks like its the 23+ for me then.
Interested to know if you had any import duty/vat to pay and how much the Royal Mail added on, partic as Switzerland is not in the EU so think like from the Far East anything over 18 is liable for duty ? or were you lucky and it came though ok ..
Old 24th March 2013, 09:17 PM   #278
The UK customs people have never charged me import duty for anything I have ordered from out of the UK. I have not made any purchases for more than 50. For low value items, they do not seem to bother. I have done over a dozen out of UK purchases-- never had a problem.
Old 26th March 2013, 07:04 PM   #279
mudihan is offline mudihan  United States
Default Getting rid of the pot in UAE23+
If I desolder the pot, does anyone know which sets of points I should short to provide a set of bypass for the L/R signals?
Composing music>Playing Music>Listening to music>The equipments you use to listen to music
Old 26th March 2013, 10:50 PM   #280
sharpi31 is offline sharpi31  United Kingdom
Use an ohmmeter to see which of the three wires connected to each channel of the pot is connected directly to signal ground. Ignore that one and join the other two :-)
Hifimediy ES9023+TE7022 24/96 USB DacHide this!Advertise here!
TE7022+ES9023 mini toy^_^ hifimediy PC Based 23 1st March 2013 07:20 AM
New 24/96 usb converters sendler PC Based 0 7th October 2010 10:10 AM
USB to SPDIF that does 24/96 and works in linux morfic Digital Line Level 0 26th June 2009 11:04 PM
Musiland Lilo 3 - 24/96 USB to SPDIF? Kane Williams Digital Source 15 21st August 2008 12:14 PM
m-audio "transit" usb 24/96 dac and digital i/o Mark Hathaway Digital Source 2 9th January 2005 05:13 PM
