Hifimediy ES9023+TE7022 24/96 USB Dac
Old 23rd February 2013, 08:45 PM   #261
Neutrality is offline Neutrality  Denmark
I am actually considering making such a board, I just do not have the time needed for making such a board at the moment.
However, there will be a Bragi MKII sometime in the future.
Changes would be getting rid of the volume pot, it is not really needed and I am not even using that option myself, I just put jumpers in instead of the pot.
So basically, remove volume pot, add AD1896 + supplies for it, change crystal to 24.576MHz, possible using U.fl connectors for the digital input. Then I would have to rearrange a few components and it should be done.
But it is just an idea I have, maybe I will have something to show a few months from now.
Old 24th February 2013, 01:11 PM   #262
Nanoloop is offline Nanoloop  Hong Kong
I search Taobao for ES9023. Maybe it comes to Ebay ? Maybe no.
US$30 TE7022L+ES9023 USB DAC ͬSPDIFI2S-Ա
Old 27th February 2013, 03:56 AM   #263
I fitted Epson XG1000 50Mhz SAW to MCLK pin. The stereo space got bigger and isolator is better too. For Epson, I use power from Tenor 12Mhz with 1uF + ferrite + 100nF. I use sox resampler + KS. This is great sound from cheap parts. Amazing.
Old 27th February 2013, 06:08 AM   #264
cogitech is offline cogitech  Canada
cogitech's Avatar
Doesn't it bother anyone that the TE7022 doesn't do 88.2?
This drove me nuts until I replaced it, and I still can't figure out why they left that out.
Old 27th February 2013, 11:07 AM   #265
soundcheck is offline soundcheck  Germany
The TE7022 is not supporting asynchronous USB. I'm wondering if there is a similar (in terms of cost and performance) chip that runs asynchronous.
Regarding Tenor: E.g. Audio-GD pretty quickly got away from those asynch TE80xx Tenor chips, which were supposed to be even better, though more expensive , then the TE70xx ones. ( Now they use VIA Envy VT1731 - no, no XMOS)
Old 27th February 2013, 12:09 PM   #266
KlipschKid is offline KlipschKid
CM6631A is asynch and not expensive.
Old 27th February 2013, 02:11 PM   #267
cogitech's Avatar
Indeed, and it supports every common combination of sample rate and resolution, all the way up to 192/32.
It was an easy choice for me.
Old 27th February 2013, 03:37 PM   #268
cogitech's Avatar
BTW, soundcheck, the CM6631A works perfectly plug and play with kernel 3.7.6. Full USB2Audio mode all the way up to 192/24. Without a hitch.
Old 28th February 2013, 08:41 AM   #269
Interesting. I'd guess a 39$ DAC with async USB and some of those tweaks that's been discussed over here applied, looks like a very appealing device.
Perhaps somebody should give HifiMeDiy a hint.
Though I'm not sure if the ADUM isolator of the DAC 2 -- which seems to be doing quite a good job -- would still work with the CM6631A.
Cheers
Old 28th February 2013, 08:44 AM   #270
I'm still using my SBT Touch with Toslink out to the DDX320.
Havn't found anything better yet.
A USB dac I'd use as backup solution. But it's good to know that those work under Linux.
Hifimediy ES9023+TE7022 24/96 USB DacHide this!Advertise here!
TE7022+ES9023 mini toy^_^ hifimediy PC Based 23 1st March 2013 07:20 AM
New 24/96 usb converters sendler PC Based 0 7th October 2010 10:10 AM
USB to SPDIF that does 24/96 and works in linux morfic Digital Line Level 0 26th June 2009 11:04 PM
Musiland Lilo 3 - 24/96 USB to SPDIF? Kane Williams Digital Source 15 21st August 2008 12:14 PM
m-audio "transit" usb 24/96 dac and digital i/o Mark Hathaway Digital Source 2 9th January 2005 05:13 PM
