| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#211 | |
To be fair I think that a optical in would be much more useful. There are a lot of cheap dvd/bluray player with awful dac converter and optical output Last edited by azimut; 27th January 2013 at 03:31 PM. |
#212 | |
The USB receiver IC WILL accept a SPDIF stream and send it to the PC, but you would have to modify things. I have never done this.
http://www.gfec.com.tw/c/document_li...&groupId=19499 is the TE7022L datasheet location. I am not positive what you want to do, but old Mac Pro towers are very cheap [at least in USA] and have dedicated Toslink in and out ports, great for capturing old DAT recordings [so are the newer Macs]. Where I live we're lucky to be able to sell off an old G5 Mac for over $100USD if that. They can run Audacity, and OS 10.5.8. As to the UAE23 family, it would be pretty easy to get some geniuses together here... to MOD the thing. I suspect there are a few pads and traces that go to the pin 33 of the TE7022L on the PCB, if not it would be difficult. Mine are not handy here at the dining table but I will look later. [seek out un-used pad or trace that goes to TE7022L pin 33] Regular coaxial SPDIF is probably easier to MOD in, just a guess. HifimeDIY could also release the information; there is nothing in their DAC that is any trade secret. I have reverse engineered the parts *I* care about. Quote:
#213 |
Hi, consider different using of SPD signal, we have some pads/parts on board which show below. Just use some 22ohm 0805 resistors to jump the signal path you need.
#214 | ||
#215 |
There ARE quite a few people who need a way to get old MD and DAT audio back into the PC [I am just commenting not arm-twisting, hah, I do plenty of that too]. I suspect one could couple copper SPDIF to that pin [pad] with a transformer, or, Lampizator-style: 75ohm resistor to center of coax to a DIY SPDIF-IN RCA? Possibly easier with UAE23+ if it too has artwork to TE7022L pin 33. I have a UAE23 in a metal box, easy for ME -- but no need. Now with a bit of creative soldering you CAN have the optical OUT working same time as feeding two RCA audio jacks left/right audio, with the DAC just about stock.
#216 |
Hello,
bought this little thing (UAE23+) as a recommendation from my friend. Came from Belgium to Slovenia in 5-6 days... Used with Foobar 2000 and wasapi, Rotel amp and Jamo E825 speakers with Jamo D4 subwoofer but I'm having a problem bass is absolutely awesome and very strong. I cannot use my subwoofer anymore there is no need for that...
#217 |
I have put out to pasture my SB Classic + Bravo tube amp v2 .
I Formatted a Lenovo x41 win 7 + fidelizer + Foobar + Hifimedy Sabre Dac Teralink Drivers + Grado SR 80i With 24/96 files I don’t only hear music I hear the angels sing |
#218 |
Im am really sad and confused because i'm struggling with a Code 43 error ( USB device not recognised )at my Windows 7 install at my Supermicro X7DCAL with Intel 5100 chipset and Asus EEE pc and others. I only got it working on windows XP with DFI Lanparty Nforce chipset motherboard , and yes i like the sound very much . Please can you help saying in what kind of computer motherboards or notebooks , you have it working ? Tnks
#219 | |
The TE7022 USB receiver USUALLY works driver-free, however there are drivers that you can install while the USB DAC device is "unplugged", the Teralink drivers {bottom of page HERE}:
HiFimeDIY Sabre USB DAC. 96khz/24bit - ES9023+TE7022 + USB to optical converter or, Dr DAc Nano drivers: ESI - Download Try using built-in USB ports vs plug-in cards with ports, you can uninstall the USB drivers and "HUB" in Device Manager and have the core USB support redetect and install. read both pages HERE: Unknown Device - USB error Code 43 - Microsoft Community Then install Teralink or Dr DAC Nano drivers {32 or 64-bit}{optionally}, then plug in the DAC after driver installation {if you chose to try a driver}. On some systems there is a internal device such as a SD card reader or internal camera which may not install properly, and also give you an error. Pull out any cards you do not need. On EEE PC look up at manufacturer for any drivers for built-in devices. The UAE23 is not problematic for most people; the TE7022 USB receiver it uses {the USB part} is very common, proven, reliable, and well regarded in it's class -- WAY more free of headaches than some of the newer "high tech" USB receivers {SOME plagued with SERIOUS flaws}. For most people this cute little DAC just works. Quote:
#220 | |
Also read the bottom post HERE:
NwAvGuy: ODAC May Update you see, the UAE23 is VERY similar to the ODAC, at least USB receiver wise. The bottom post there [today yet] is by the guy who helped design ODAC using the TE7022. READ: you MAY have other problems. Quote:
| TE7022+ES9023 mini toy^_^ | hifimediy | PC Based | 23 | 1st March 2013 07:20 AM |
| New 24/96 usb converters | sendler | PC Based | 0 | 7th October 2010 10:10 AM |
| USB to SPDIF that does 24/96 and works in linux | morfic | Digital Line Level | 0 | 26th June 2009 11:04 PM |
| Musiland Lilo 3 - 24/96 USB to SPDIF? | Kane Williams | Digital Source | 15 | 21st August 2008 12:14 PM |
| m-audio "transit" usb 24/96 dac and digital i/o | Mark Hathaway | Digital Source | 2 | 9th January 2005 05:13 PM |
