| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#201 |
What is the output filter capacitor?
io |
#202 |
I did a google search for DAC filters. Here is a document that you might find interesting:
http://www.analog.com/static/importe...als/MT-019.pdf
Just the facts! State your evidence. |
#203 | |
On thread I read, a guy used 1k each leg and loves it, I'd probably stay closer to the proven ODAC, maybe 220 or 470... I am also fooling with the Vreg pin #6 on es9023 [Ess says ~10uF and have the 2 graphs on pg 10 of the design PDF for value of parallel R to ground depending on Vcc used for the DAC 3.6 vs 3.3. ODAC uses 118K and 22uF -> I am trying 100K and 10.1uF because I had a SMD R around that value to try [stock UAE23 seems not to have an R to ground off pin #6 I could be wrong, but it seems not.] |
#204 |
postman just brought UAE23+
It's a nice little box. Not hifimediy production anymore but Hifime Audio Studio. A new brand ![]() UAE23 looked like a toy. + version looks like a commercial dac, nicely finished in metal box. In my mayuseoneday box , i found a suitable 9Vdc powerplug Dac was immediately recognized by my laptop running windows 7 as "DAC Hifimediy (Sabre+ 24/96)", same as previous. I use default windows driver. UAE23+ sounds very nice. ES9023 sound is there. To my ears, it's hard to hear a difference with the non-isolated version. Difference must be tiny, especially if no grounding issue existed with USB. I'll measure them both later and see if I can find a difference. |
#205 | |
Maybe you have less noise to start with? Having used fiber USB isolators, everyone in my family I give one to is happy. Silent regions are more quiet it seems. I live in a city, when I walk outside, there is a "city noise", I don't notice it but if it were gone, I might.
I'm pleased HifimeDIY added USB isolation; nobody has that feature at any where near this price-point. And as a DIY nut, the 23+ should be easier to MOD into something even nicer. The flexible range of power sources...more space... RCA jacks... a external power jack that can take AC or DC sources... Quote:
#206 | |
looking for. The hifimediy.com website states "Optical input to USB" but where would the optical input be ? Canīt see it on the photos provided.
Regards, Georg |
#207 |
Received this Dac in exactly one week, quit fast from China to Holland. It is the new + version, so I can try it also as a usb to spdif converter.
I play my music from an Imac. The Dac is recognized immediately as a Sabre 24/96 device. For playback I use Bitperfect, a software utility for better audio output. Bitperfect has the opportunity for upsampling to 96 kHz. I was surprised that upsampling did not improve the output-sound. To much bass. So I turned it off and now I am quit happy with the overall sound. I still have to compare it with my HK-dac, which lacks the usb input. And try it as a usb-spdif converter through the HK-dac. So lots of possibilities to try. And many hours to come with listening. Will be continued. |
#208 | ||
#209 |
The allusion to optical input may have been a slight mistake; the TE7022 can take the input but I think the standard UAE23 OUTputs optical, not like the outdated picture on the site, but right behind the upgraded UAE23 3.5mm "Walkman" port is a red LED emitter -- being only a 2-lead device I doubt the stock vanilla UAE23 could input SPDIF from the optical arrangement it has. They MAY have input circuitry hiding in there they can mod for special customers. My guess.
#210 |
enjoybiking, you are correct:
I asked HiFimeDIY directly and got this answer: "we discovered that we had to chose one, either optical in or optical out. We decided to stay with only optical out, as that can be useful to most customers. I have updated /removed the reference to optical in, but as we have this listed on several sites, there might some places where this information is still present. I apologize for any misinformation about this." So it seems there is no optical in -> USB. Itīs nevertheless still an interesting product, especially for the price asked. Does anybody know of a similar product that has digital in and out to USB ? I own a DAC, an RME ADI-2, where A/D and D/A are independent and can be used at the same time (24bit, 192kHz). This is connected to a RME Digi96, a PCI card with digital I/O (24bit 96kHz). What I want to achieve is the same thing over USB (maybe with 192kHz capability if possible), so I can use a Laptop instead of the old PC with PCI slots.
Regards, Georg Last edited by gk7; 27th January 2013 at 08:21 AM. |
| TE7022+ES9023 mini toy^_^ | hifimediy | PC Based | 23 | 1st March 2013 07:20 AM |
| New 24/96 usb converters | sendler | PC Based | 0 | 7th October 2010 10:10 AM |
| USB to SPDIF that does 24/96 and works in linux | morfic | Digital Line Level | 0 | 26th June 2009 11:04 PM |
| Musiland Lilo 3 - 24/96 USB to SPDIF? | Kane Williams | Digital Source | 15 | 21st August 2008 12:14 PM |
| m-audio "transit" usb 24/96 dac and digital i/o | Mark Hathaway | Digital Source | 2 | 9th January 2005 05:13 PM |
