| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#101 |
If you haven't tried it, get a cheap adum4160 USB isolator and linear dc supply. The one i posted earlier is really nice as it has its own shunt reg for the dac supply, and was pretty cheap. The isolator and linear supply removed a nasty layer of harshness from my dac. I wonder if sensitivity to USB voltage rails noise, and different noise spectra with different pcs, could be causing the forward mids that some hear and others don't.....
#102 |
I too have found that USB Isolation works GREAT, with TE7022 anyway.
I have some leftovers from that effort BTW, I have around 30x Opticis M2-100-03 3M 12Mbps fiber optic based USB isolators, they come with {sigh] a switching PSU for the device-end, at least it has ferrite on BOTH ends of the DC cable. PM me if interested in any at ~1/2 what you'll find on the net. These would NOT be for 480Mbps USB traffic. Perfect for the TE7022 and PCM27## USB receivers. I also took 2x of these to my Brother-in-law who tried them on his TE7022/Wm8741 and TE7022/CS4398 DACs [we use only USB and FLAC]. I also use a TE7022//CS4398 [with silly USB-powered op amp bypassed and plenty of filtering and bypass caps added, that DAC and the one at my Sister and Bro-in-law's being the same -- and both wired DIRECT OUT to RCAs, not even caps]. Sounds better! Tests were into Magnepan MG3.3R, some studio monitors, and some Genesis Genre I. [The Monitors are modded with some Monsoon planar-magnetic drivers for the mids]. All very revealing. I am not a wine-taster, I know there should be less noise and confusion and, IMHO, isolation is worth doing. I DID mention to HiFIMEDIY that adding a ADUM4160 to the existing DAC artwork would, in my opinion, take it to the next level. The isolator and a DC-IN jack for power. Just a thought. |
#103 | |
The HifiMeDIY DAC is a great piece of kit, especially since it is so affordable. I'm actually giving one as a gift to a audio-enthusiast friend of mine. I am not attempting to disparage it, just to give my analysis of it as honestly as possible. FWIW, My friend gave me a grubDAC this past week and I compared it to this DAC. This DAC is clearly better than the grubDAC that I have in hand. Last edited by mfaughn; 15th December 2012 at 12:25 PM. |
#104 |
For this dac, does the es9023 run on 3.3v supply? I see only one LT1763 chip so i this it is the case. I read some where about using 3.6v for es9023. I have just ordered this DAC and I am thinking about making a separate power supply for it rather than using USB power. I have also order the teralink isolator.
Quan Tran |
#105 |
[URL=http://www.esstech.com/PDF/ES9023%20PB%20Rev%200.2aPB%20110117.pdf[/URL]
/lohk/ |
#106 | |
From the other hand, HRT sound signature might and should be different from them both and that's another story, I did not hear it on my gear and can only rely on reviewer's impressions. Did Sabre DAC based units have forward mids or HRT+ have recessed ones - that could be subjective and ear/gear related. But anyway PCM1794 is good old but not as stellar DAC as Sabre is.
Yuri |
#107 |
I have read this document, not much information inside. I am looking for the datasheet ...
I understand that it works better with 3.6v but the design of hifimediy uses only one regulator for 3 ICs including the es9023 so i think it runs on 3.3v due to sharing ps with other chips. This dac looks to have a great potential with power supply upgrade. Some member already mentioned the improvement when used with usb isolator. That way the dac is actually powered by the usb isolator...
Quan Tran |
#108 |
Quan:
http://www.yoyodyneconsulting.ca/dow...AC-release.pdf I see 1.8V 3.3V 3.6V and LOTS of caps! A choke... I do not know the rules about USB power. Even though I have USB isolation now to my various TE7022 I wonder about the poor man's solution? Can you just cut the 5V from PC and insert say a 7805 and external power for down-stream? Does one have to place a fake load on the PC +5V? |
#109 |
One TE7022//WM8761 DAC I've modded numerous times comes with a full-wave bridge and 7805 after a coaxial power plug and "USB vs external" toggle switch. Batteries would be an option, many of us have dead laptop batteries with a few good 18650 left -- charging those... one guy:
LED Bike Light projects [3/4s the way down the page] he just mods chargers... I like the chargers with separate monitoring LEDs-per-battery-bay. 2 banks placed in series after charging could hit around 8.2Vdc and eventually sag to maybe 7.6Vdc . I have never had a Lithium exPLODE but I hear they DO so I would not suggest too crude a DIY. |
#110 | ||
| TE7022+ES9023 mini toy^_^ | hifimediy | PC Based | 23 | 1st March 2013 07:20 AM |
| New 24/96 usb converters | sendler | PC Based | 0 | 7th October 2010 10:10 AM |
| USB to SPDIF that does 24/96 and works in linux | morfic | Digital Line Level | 0 | 26th June 2009 11:04 PM |
| Musiland Lilo 3 - 24/96 USB to SPDIF? | Kane Williams | Digital Source | 15 | 21st August 2008 12:14 PM |
| m-audio "transit" usb 24/96 dac and digital i/o | Mark Hathaway | Digital Source | 2 | 9th January 2005 05:13 PM |
