E-mu 0404 problem
E-mu 0404 problem
Old 24th August 2012, 10:57 PM   #1
tonyptony is offline tonyptony  United States
Default E-mu 0404 problem
At least, I think it is. I've had my external 0404 for a number of years and it has worked fine until recently. I use it with a Behringer ECM8000 and TrueRTA. I set it up the other day and it all seemed normal - all the lights lit up including the 48V phantom power light. When I went to look at a reading on TrueRTA I got nothing. I lightly tapped the mic and still nothing. I tapped just a little harder and saw the trace rise up from dead bottom and then settle back down.
Thinking the mic had died, or the cable had maybe developed an open, I plugged the mic into my Fender guitar amp with the original cable and another one. In both cases the mic worked properly with the Fender.
I checked TrueRTA to make sure it was still set to use the E-mu as the input device (it was). Win XP showed the E-mu as working properly installed in Device Manager. This laptop has had no changes to it since the last time this worked. I'm afraid my E-mu is borked but I'm not quite sure how to figure out what's worng. I have experience in troubleshooting things, but I could use some help for this one.
Old 24th August 2012, 11:14 PM   #2
wwenze is offline wwenze  Singapore
Switch on Direct Monitor and plug your speakers to the main out. If the mic still does nothing, at least you know it isn't software/digital circuit related.
Old 25th August 2012, 01:00 AM   #3
I used a phono to RCA adapter so I could connect one of the main out channels to one of my active speakers. Set the Direct Monitor to Main and Mono to On. Nothing. I made sure the output pot and the gain pots for both A and B inputs were maxed out. Tried both inputs with the mic. Nothing. The signal intensity ramp lights on either input weren't moving.
E-mu 0404 problemHide this!Advertise here!
E-MU 0404 USB Modification? lumanauw Digital Line Level 238 29th July 2017 01:40 PM
WTB: E-mu 0404 or 1616m pcie prooptiki Swap Meet 0 11th April 2012 08:18 AM
Need help possibly repairing my e-mu 0404 SilverStrings Digital Source 20 10th February 2012 12:54 PM
FS: E-MU 0404 PCI soundcard RichLund Swap Meet 1 13th December 2010 02:03 PM
Copyright ©1999-2017 diyAudio
