| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#21 |
natehansen66 - how do you input your digital sources ?
#22 |
Hi!
I use Echo's Gina24 it is a great card and can be found occasionally on ebay for around $200 or so. Yes it is an older card but it can be found. Here is one on Amazon, Amazon.com: Echo Gina 24-Bit Multi-Track Digital Recorder Card: Musical Instruments It is a Great sounding no frills card. I have less (no) issues with it as much as I do when I try to use my X-FI Elite Pro system using Live Host's and vst's. I have found that Creatives Mixer is a PITA to use and does not play nice when it comes to Live Professor which is the program I use. Although I did get it to work. I haven't tried any of the other programs with it yet with it as I am about to switch back over to the Gina24 anyhow because of it's ease of use and never had even one problem with it. FWIW jer
#23 |
I forgot to mention that I am using Windows XP64 and could not got either of my cards to work in Win Vista or in Win7.
jer
#24 |
I'm not sure what you mean? All my digital sources are either on my hard drive or online media. In either case the digital audio is sent via firewire to the interface.
If I remember from my reading correctly the Gina/Layla cards are no longer being made and Echo is not going to update the drivers for Vista/Win7. |
#25 |
Master Burner
Muskel,
what you are trying to do could be very challenging if you would like to mix sources, such as S/PDIF, digital files and video. It is not impossible, but extremely challenging and potentially expensive if the utmost quality is your choice. If you play only digital files, than that is no problem on any platform - Mac or PC, but mixing brings a lots of limitations. That is the very reason I decided to give up that rout after being frustrated that just switching from digital files to S/PDIF created a big deal. I also hated that I constantly had to do something in software, and than when I wanted to play internet radio, I was barely able to do so with huge frustration. If you still decide to go forward, and would like to use an audio interface I would gladly recommend RME Fireface 400 or 800, but they are above the budget you have set. As for the drivers they are the top of the line... untouchable. Allocator is absolutely the best Xover software I played with. But, out of all option, I think you might want to give a glance at DCX2496. The beauty with that is that it is a stand alone unit, so it works regardless of computer. There are really high quality upgrades that turns that average unit into exceptional one. If interested you could do piece by piece upgrade, but unit works from the point you turn it on. And no latency issues ether, so mixing various signals is not a big deal. Sure, you could do a lot more in the terms of equalization with your PC Xover, but also you could do much worst, as well, if you overdo it.
www.burningamp.com Last edited by AR2; 12th September 2012 at 03:20 AM. |
#26 |
is choosing a less facetious title...
second the RME, drivers have no parallel. in 5 years I NEVER had a driver related crash or glitch and the mixer is extremely flexible. you could pick up a used one fairly easily too, its had a few versions.
#27 |
Yes,natehansen66, I am aware of this,Thanks!
I thought that I would mention it as they do have some drivers on their website. But in my case they just do not work for the latest versions of windows. I had just saw a Gina 24 card on Ebay for $50 right after I had made my last post. I have the same issue with my X-FI card as well, But I did just recently discovered a new third party installer for that card but I have not tried it yet. I was thinking that it was just my old motherboard but the system runs Win7 and Vista just fine. It is a Asus A8V-X and a Opteron 185 oveclocked to 2.95Ghz. If I get a chance I will try them in our new FX-6100 build sometime, as that machine belongs to my mother and I will have to try it some time when she is not using it. My point was that it could be done on the cheap with some good ole (old) quality components using WinXP 32 or 64. jer
| PC based digital crossover with dolby digital live | preiter | PC Based | 64 | 25th April 2012 08:14 PM |
| Digital Crossover | JBdV | Digital Line Level | 12 | 15th December 2010 12:29 PM |
| Progress report - digital crossover as a DAC - digital all the way to the amps | Ken L | Multi-Way | 0 | 26th November 2006 11:42 PM |
| digital crossover w/digital output? | ezkcdude | Multi-Way | 30 | 3rd August 2006 01:01 AM |
