Digital crossover for 3-way speakers
Old 25th February 2017, 12:47 PM   #41
plasnu is offline plasnu  United States
It is a very difficult choice between FIR vs IIR. I went back and forth many times until I ended up choosing 260000 tap FIR, but IIR still sounds slightly better in some way, when comparing IIR vs FIR with the same phase response.
I wouldn't be using FIR if I would not have needed phase correction. FiR is a double sided sward.
Old 26th February 2017, 08:11 AM   #42
muskel is offline muskel  Estonia
Fenalaar, i would buy the curryman DAC, but i need balanced output via XLRs so i still need to sort out the what dacs to use. One option would be to use backplane output boards like this in a 2U case: https://www.minidsp.com/forum/sugges...alanced-output FIR is just for experimentation in case i need it. Plasnu, i have a pc and i will use it, but the audio system still needs to be usable - i feed it a signal via spdif and it plays the sound, be the source video, audio, a pc game etc.. Im planning to run 96khz anyways if possible. What hardware did you use to achieve 260000 tap FIR?
Old 26th February 2017, 02:09 PM   #43
Fenalaar is offline Fenalaar  Norway
XLR outputs? How about the Twisted Pear Opus dacs, then? They're $75 a piece for stereo modules, and they offer balanced outputs.
A 260000 tap filter has serious amounts of latency, so it would be of little us with video.
The latency is calculated as
(N - 1) / (2 * Fs) where N is the number of taps and Fs is the sampling frequency.
A 2048 tap filter at 48kHz has a latency of 21ms.
A 260000 tap filter at 96kHz has a latency of 1.35 secs. At 192kHz, the latency is still at .67 seconds.
If you do crossovers and use different FIR lengths, you need to account for the difference in latency.
Johan-Kr
Old 26th February 2017, 09:36 PM   #44
muskel, my computer is Mac Mini i7. It is also used as a music server with Tidal and iTunes. You can buy a second hand, balanced out, multiple channel, excellent pro audio interface for $100-$2000. Pro audio is a matured market and the price is not unreasonable like consumer audio interface. Gearsluz.com is a good place to research pro audio equipments.
Fenalaar, 260000 tap with a latency of 1.35ms@96K is a theoretical limit. My setup has a few times more latency than that to avoid occasional clicks.
Old 28th February 2017, 06:46 PM   #45
plasnu - the latency is seconds, not miliseconds.
Johan-Kr
Old 2nd March 2017, 05:47 AM   #46
Johan-Kr
yes. typo. My current latency is probably more than 2 sec.
Old 2nd March 2017, 07:54 AM   #47
For audio only, a latency of 2 seconds or more wouldn't really be a problem. Video would be a problem.
260000 is a bit of overkill, I feel.
I did a test with my Minisharc, and downloaded the 2x2 plugin in addition to the 4x8 plugin.
Running it two-channel as a correction unit for my passive speakers, the difference in accuracy in the bass with 6000 taps per channel (2x2 plugin) versus only 2000 taps is apparent.
I'd use IIR eq to start with. As most of the speaker problems are minimum phase, straightening the response with IIR will automatically fix phase too. Then use FIR to do XO and remaining phase problem. If using the minisharc in 4x8 mode, I'd limit FIR usage below about 150Hz as much as possible.
Johan-Kr
Digital crossover for 3-way speakersHide this!Advertise here!
digital crossover w/digital output? ezkcdude Digital Line Level 44 22nd May 2018 10:10 PM
PC based digital crossover with dolby digital live preiter PC Based 64 25th April 2012 08:14 PM
Digital Crossover JBdV Digital Line Level 12 15th December 2010 12:29 PM
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 26th November 2006 11:42 PM
