CM6631 usb audio interface .... any good ?
Old 10th February 2014, 01:33 AM   #481
wklie is offline wklie  Hong Kong
Originally Posted by badboygolf16v View Post
Unfortunately I cannot see the device in FW update tool after deleting and reconnecting.
Any advice? Using FW tool 2.0.1.9 and W2K8 Server.
Find a Windows XP or 7 PC to try again.
Old 10th February 2014, 07:26 PM   #482
badboygolf16v is offline badboygolf16v
I've got a Windows 7 laptop and am running v 2.0.1.9.
The utility reports Device Name USB\VID_047B&PID_0101&REV_0102. Selection of firmware is allowed but nothing happens when I select a firmware to update, apart from the Update FW and Erase FW buttons are greyed out.
Any suggestions?
Old 13th February 2014, 07:52 AM   #483
tdtsai is offline tdtsai  Taiwan
I donot think this is C-Media device's ID. You should choose other ID in list. The Utility report all use device in list you should choose right device.
Any suggestions?
Old 4th April 2014, 03:32 PM   #484
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
I'm trying the DIYinHK (isolated) CM6631A board, and same vendor's ES9018 board.
glt mentioned that you can play 44100 files with this combination, and it works fine - despite the BCLK coming out at 128 fs, instead of the 64 fs required in the ES9018 data sheet.
I tried it like this, but I do not like the sound. It sounds OK at first blush, and the 3D space is quite pleasant. But it sounds nothing like natural acoustic music - it's mechanical sounding.
LP source through same amp/speakers sounds wonderful.
The board has been configured:
- ADP150 for clock supply, preregulated at 5V. Clock is EPSON-Toyocom SAW 100MHz;
- ADP150 for DVDD supply, preregulated at 5V, (separately);
- ADP151 for DVDD 1.2V supply, preregulated at 2,5V, (separately);
- ADM7150-3.3 for AVCC supply, preregulated at 5V, (separately, separate transformer/rectifier to above supplies).
- voltage mode output (until I get it good enough sounding to apply my I/V method).
It sounds a lot better with 96000 files, so I have looked harder at it. I tried to use the FW updater, to change the 44100 BCLK to x64, but this app just quits without displaying anything, on my only windows PC (all my other computers are on Linux/Kubuntu 12.04 - Kernel 3.2.60).
Next, I scoped out some sinusoidal WAV files at 44100 - which look terrible! Admittedly, there's only a 22nF PPS cap across the phases ('Rasmussen Cap') by way of output filter.
So, I used SoX to upsample the sine WAVs to 88200:
sox infile.wav -r 88200 outfile.wav
and found that at 88200, which drives a x64 BCLK, normal sines are presented.
This seems to suggest that the ES9018 really does need a x64 BCLK, and x128 is really not suitable.
attached scopeshots: 10k 44100 - 10kHz 88200 - 20kHz 44100 - 20kHz 88200, played with DeadBeef on Linux Kernel 3.2.
Old 4th April 2014, 03:35 PM   #485
работник
jpegs uploaded for quicker viewing.....
Old 21st May 2014, 05:25 AM   #486
sergedc is offline sergedc
Default USB device not appearing in Update tool
Hi guys, this thread seems like it may be useful for my problem. I am trying to use Breeze Audio CM6331A USB to SPDIF via ALSA on RPi.
I have followed advice to delete firmware and disconnect then reload firmware. Unfortunately I cannot see the device in FW update tool after deleting and reconnecting.
I had the same problem. This is how I solved it (I know it does not look scientific but did it 3 times and worked each time):
- Connect the usb
- open tool (I use win 8)
- the USB device is not there (that's when I paniqued!)
- withdraw the usb plug (but not fully) and plug back in very quickly. Basically tickling the usb plug a bit.
- the usb device showed up in the FW update tool, and I then updated the FW.
Doing this I downgraded from 0108 to 0101 and I can now use the OTG with my samsung note 3
Old 24th May 2014, 04:08 AM   #487
Druid is offline Druid
Hi, guys, i saw this: Assembled CM6631 Daughter Card for TDA1541 AK4399 Parallel SN | eBay
It said it's for TDA1541, anyone tested it yet? and i can't find the USB input in this board.
Is there anything i can do to make CM6631 use with Tda1541?
Old 26th June 2014, 06:49 AM   #488
wiktorsam is offline wiktorsam
Hi all
I have problem with my breeze audio cm6631 usb spdif dac. I bought it here: Finished HIFI DAC Decoder CM6631+CS4398+OPA2132 24Bit/192Khz USB input with RCA headphone and COAX output with case-in Amplifier from Electronics on Aliexpress.com
The first problem was that device didnt work propertly - was unrecognised by system. The solution was to update firmware with proper version - my device have cm6631a chipset but was flashed with cm6631 firmware. After update the device started work propertly but i have one more problem.
I cant use any resolution above 96kHz. I can select it in audio device properties under control panel but when i set in example 192kHz 24bit i have no sound, only background noise. When i connect to the device external spdif DAC witch is capable to use 24bit 192kHz i hear sound with 16bit 176kHz resolution, but higer settings didnt work also.
Have you any idea what can be wrong with my device? I tried flash it with different versions of firmware and tested it with different drivers but this didnt work for me at all.
Its not big problem for me because dac have very good sound. The headphone port have very good sound also. But if the device have capability to set higher res, i want to try it
Sorry for my english and thanks for your response.
Best regards
Old 28th June 2014, 05:31 AM   #489
trcloud is offline trcloud  China
Well I think a musicland 01usd usb soundcard can have a better performance than CM6631 or XMOS device
Old 14th July 2014, 07:52 PM   #490
Boscoe is offline Boscoe  United Kingdom
The resources are great in his thread but it is also very long. Could someone point in the right direction for a schematic application for the CM6631A?
Boscoe
Audio projects and more: gswdh.co.uk
CM6631 usb audio interface .... any good ?Hide this!Advertise here!
USB Audio Interface oodi Digital Source 6 30th December 2011 07:59 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Recommendation on good USB-SPDIF interface? kop89 Digital Source 13 2nd August 2008 07:51 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
