CM6631 usb audio interface .... any good ?
Old 25th January 2013, 03:10 PM   #111
factory2nd is offline factory2nd
The board is the chepest one, i USe it in i2s and i've the ns192 cd trasport that work well at 192 via i2s
Old 25th January 2013, 03:13 PM   #112
KlipschKid is offline KlipschKid
ASIO driver ? Windows ?
Old 25th January 2013, 03:25 PM   #113
Win7 foobar wasapi sox resampler
Old 25th January 2013, 03:31 PM   #114
If you want help, you have to do better than repeating what you wrote before hoping that's an answer. Read my my first reply to you again. I'm telling you to check your computer. You should use ASIO, not WASAPI, unless you have changed the device manager settings.
If that doesn't work, contact the seller.
Old 25th January 2013, 03:57 PM   #115
I've tried to set Windows, at 24/96 and work good, at 24/192 there is a lot of noise (but you can ear the sample sound) and after restarting the dac only silence
Using asio i'm able to select 192 but the dac remain on 96!
Thanks for your help!
Old 25th January 2013, 03:58 PM   #116
Asio derivers are supplied by the seller!
Old 25th January 2013, 04:05 PM   #117
The problem is your computer settings. I'm not going to keep repeating myself. If you can't fix it, contact the seller.
Old 25th January 2013, 04:17 PM   #118
I surrender, obiouvsly i'm not able to set the pc, i sent a pm to the seller, i Will post the answer!
Many Thanks!!!
Old 25th January 2013, 05:46 PM   #119
roygbiv9850 is offline roygbiv9850  Poland
You must write all hardware configuration, about used IC's
Old 29th January 2013, 09:08 AM   #120
tdtsai is offline tdtsai  Taiwan
If your DAC is use CM6631 it does not support 176.4 kHz I2S output. If your DAC use CM6631A it can support 176.4kHz I2S output.
Originally Posted by regal View Post
Is there a 176.4 khz i2S output firmware for this chip yet ?
CM6631 usb audio interface .... any good ?Hide this!Advertise here!
USB Audio Interface oodi Digital Source 6 30th December 2011 07:59 PM
usb audio interface david12 Equipment & Tools 14 10th October 2010 02:58 AM
Recommendation on good USB-SPDIF interface? kop89 Digital Source 13 2nd August 2008 07:51 AM
Cheap Audio Interface (USB?) to PC agm2003 Instruments and Amps 11 16th September 2007 07:48 AM
USB Interface Perfect?- Computer Audio fmak Digital Source 3 4th December 2004 10:24 PM
