DIY DAC....is this any good - Page 11 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd September 2012, 10:15 AM   #101
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I reckon its OK - the datasheet isn't very clear about the maximum die temperature but says the maximum ambient is 85oC - if you can hold the back of your hand against the ally then its probably no hotter than 60oC.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 6th October 2012, 12:20 AM   #102
The DAC is sounding great with just my caps on the output to eliminate DC bias. Is there any need for anything more complicated on the output to remove the DC bias? I try to keep minimal components in the signal path in my audio builds. Speaking of signal paths,.
Another project of mine: (a very big one at that!)
http://www.mp3car.com/vbulletin/show...5-pimping.html
Old 6th October 2012, 12:58 AM   #103
abraxalito's Avatar
If the caps are working then no, there isn't. Speaking of 'signal paths' I'm not a believer in them though its a very common myth. Current flows in circles so the 'return path' is as important as the 'signal path'.
Old 24th October 2012, 05:58 PM   #104
Haven't posted in a while, been busy trying to build an extension on my house before me and the wife have out first baby. The DAC is still sounding great when I have the chance to listen to it. Will post some pictures when I eventually assemble my DAC/Pre amp.
Thanks again for everyone's help
Old 14th December 2012, 10:05 AM   #105
Extension finished, but my baby is due any time, so havn't had time to build my DAC pre amp, but the DAC is still sounding great, even if the DAC chips get a little warm. Nothing a small heatsink won't sort out
Old 30th January 2013, 08:02 PM   #106
It's been a long time, but here are a few pics of the 'almost finished' DAC/Pre amp:
Here is a pic of the various PCBs inside the enclosure. All PCBs are made by me, except the DIR9001 receiver board.
The pot is an Alps motorized 100K Log and is controlled via my PIC microprocessor board. This controls the 'Lightspeed Attenuator' circuit.
8 DACs in parallel and a 10mm thick piece of aluminium used as a heat sink and also part of the lid.
1 x Coax digital in
1 x Optical digital in
2 x Analogue in
and obviously 1 x output.
There is a switch which selects 'Auto' or 'On'. In 'Auto', it automatically powers up when 24 volts are present on the jack plug under it.
The dial on the left is a rotary encoder which can be used to select the input required and can be pressed to mute. When in mute mode, the power LED flashes. If you are on a digital input (1 or 2) and no valid signal is being received, it will flash that LED also.
There is quite a bit of stuff to cram into the small enclosure, but I wanted to make it the same footprint as my PSU and LM4780 chip amp enclosures.
Will post a pic of it finished soon
Old 31st January 2013, 11:30 PM   #107
A few more pics:
Inside of the rear panel
Inside of the front panel
The case with transformer, PSU board, relay board and microprocessor board
The 8 x TDA1543A parallel board attached to the lid (also used as a heat sink)
Should power it up tomorrow and test it
Old 2nd February 2013, 11:21 PM   #108
Powered up and tested this evening.....All working and sounding great.
Thanks for everyones help in this thread to complete my build
Last few pics:
And here it is with my LM4780 chip amp and power supply.
Old 10th June 2015, 01:31 PM   #109
Tripmaster's Avatar
A great little ending to this thread. I enjoyed reading that. Well done!
Old 11th June 2015, 12:25 AM   #110
surfstu is offline surfstu  United Kingdom
@Portreathbeach - had to chip in here. Made myself a baby huey ecl86 amp whilst partner was pregnant with first baby 2 years ago AND we were building an extension AND i used to live a mile from Portreath!
Partner was worried as I locked myself away building an amp, then the baby arrived and all audio obsessions stopped. Have just got back into my audio but have second baby on the way so I think this spurt of audio fascination will be shortlived again,
Loveley looking finished product by the way, am sure it sounds great too,
Stu
HLLY DIY DAC ... is it any good ? dhbiker Digital Line Level 20 8th June 2012 09:18 AM
I can't find a good diy DAC kit under $300? seawalker Digital Line Level 4 13th April 2012 10:59 PM
Looking for a good DIY PCB kit - RS ones any good? Others? Morse Chip Amps 33 5th March 2009 02:38 PM
Good sound DIY DAC senee Digital Source 4 21st May 2008 09:12 AM
DIY DAC box, what would be good chips to use? wa2ise Digital Source 6 11th June 2005 05:40 AM
Copyright 1999-2017 diyAudio
