CS8406 problem
CS8406 problem
Old 5th August 2012, 06:54 PM   #1
3nity is offline 3nity  Austria
Default CS8406 problem
Hi folks!
I've built a stereo ADC card using the ES9102C in master mode, and the CS8406 as a slave and in hardware mode. I2S format.
Schematic attached.
I'm using a Scientific conversion SC-937 as aes-ebu transformer,
recording through an old Fostex D-5 DAT machine.
Two strange thing happens:
1)
the d-5 doesn't lock to 44.1kHz, but says 48kHz, while ADC and CS8406 are actually working at 44.1.
I checked the I2S wires from the ES to the CS and the clocks are correct.
Still D-5 meter says 48, not 44.
I can hear the sound from the DAT when in pause mode, but when I record, nothing is left on the tape.
Switching ADC to 48kHz operation, everything works just fine.
Pin settings are the same, only the clocks change, I cannot understand.
2) :
On the ES9102 datasheet, the max analog input for full scale is stated as 2.2Vpp differential (0dBu, or 0.78Vrms).
If I input a sine wave, and measure exactly 0dBu on the ES inputs,
the DAT never goes beyond -6dBFS, same thing if I increase the sine amplitude, it sticks at -6 as if there was a sort of limiter.
The default value in the volume control register is 0xffffff, did not write in it, so I was expecting to get a full scale reading.
Any thoughts?
Old 8th January 2013, 07:40 AM   #2
googlyone is offline googlyone  Australia
CS8406 problem
Old thread, but it kind of looks like your DAC is looking for Left justified data rather than I2S. This right shift of the audio data between Left Justified and I2S of one bit is exactly 6dB...
CS8406 problemHide this!Advertise here!
CS8406 SPI problem mstro Digital Line Level 11 30th August 2011 03:21 PM
CS8416 and CS8406 flippo Group Buys 5 5th January 2007 07:15 PM
CS8416+CS8406 U bit data problem pkaszas Digital Source 0 17th April 2006 03:33 PM
Cs8406 mcs Digital Source 0 11th November 2004 04:05 AM
CS8406, CS8416 => 192kHz SPDIF Dave Digital Source 5 11th January 2003 03:20 PM
Copyright ©1999-2017 diyAudio
