Go Back   Home > Forums > Source & Line > Digital Line Level
Old 1st August 2012, 07:48 PM   #1
Olombo is offline Olombo  Germany
Default Multichannel DAC
Hello!
there seem to be thousands of DAC and DAC kits on the market.... but I need more than 2 Channels; at least 8! Crossovers, FIR correction etc is done in PC so I like to go out seperately for ech channel and amp.
I found 3 options:
- Buy a ordinary Audio interface (Rme UCX would be nice): Boring and quite expensive! ;-)
- Use minidsp USBstreamer and its l2s out. But then? Ok design l2s-analog converter according to example shematics I can do but is lot of work. Finished solutions I did not find with suitable DA chips (pcm179x or WM8741). Ideas or resources for finished solutions?
-Is it possible to connect more than 1 two-channel DAC to PC and use parallel but with different outputs? 4 DAC on 1 PC maybe a bit weird but if it works it may be the safest and best solution as plenty are available.
Thanks for your help and ideas for option 2&3!
Ron
Old 6th August 2012, 04:29 PM   #2
hahaha you think same me is my idea
I2S had 4 signal
Master Clock
Left Right Clock
Serial Clock
SDIN
but 4 input it should be
SDIN1
SDIN2
SDIN3
SDIN4
Uploaded with ImageShack.us
but i don't have know how design circuit
Old 7th August 2012, 07:01 PM   #3
at least one having same issues like me ;-)
But I guess I found the best solution now....
USBStreamer + Buffalo 3 DAC from twisted pear. If I understand everything right I can put in the 8 channels via I2S and get out 8 channels (4x stereo) converted by a reference dac chip. In the end not the cheapest choice (streamer, buffalo, power supply,... >500$) but a very good as it seems.
Other solutions still welcome :-)
cheers!
Multichannel DAC for recording Infernal_Death Digital Source 2 11th April 2013 12:15 PM
Multichannel DAC dunderchief Digital Source 46 5th November 2010 12:51 PM
multichannel DAC project from PC cougarz Digital Source 0 5th January 2007 07:07 PM
Multichannel DAC with 5+ RCA outputs Aetherion Digital Source 8 17th July 2006 04:53 AM
Multichannel DAC cniemira Digital Source 0 8th December 2002 04:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
