Digital source, receiver and DAC for preamp
Old 10th August 2012, 04:18 PM   #11
peizi is offline peizi  United States
Originally Posted by cowana View Post
I'm designing a preamp with a range of inputs, and have decided I want to add digital capability to it.
This will obviously comprise of the following three parts. I wish to keep everything working in hardware mode, so with no I2C/SPI control required.
The sources:
The preamp will have three digital sources:
- Coaxial SPDIF
- Optical SPDIF
- USB
The USB obviously needs a decoder. I am currently looking at the PCM2707 as it seems to have positive reviews - but any advice is appreciated.
The receiver:
The receiver needs to switch between SPDIF sources and convert to I2S. I'm looking at the WM8805 for this (in hardware mode). Am I right in thinking that this requires an accurate 12.00MHz clock to run well?
*Edit: looking further into it, I'm not sure that the WM8805 can change between sources in hardware mode (which is very poorly documented). The CS8416 is MUCH better documented and has a more capable hardware mode - would there be much of a performance downgrade to using this?*
The DAC:
I've been looking at the WM8740 stereo DAC - this seems to have good reviews. However I don't need the differential output - the datasheet shows multistage external active filters and a lot of complexity. I'm trying to make a very compact design - the CS4344 DAC is a very compact solution requiring minimal external components. I don't mind a small performance decrease in return for simplicity and a design which is more likely to work first time - so I'll probably end up using the CS4344.
Any thoughts or opinions are valued!
Many thanks,
Andy
22.1184MHZ for 44.1KHZ, and 24.576KHZ for 48KHZ or 96KHZ , 192KHZ.
In fact, we don't need preamp for DAC now, 100 ohm out put is better
Digital source, receiver and DAC for preampHide this!Advertise here!
tap digital signal on Denon AVR2809 receiver' CPLD for external DAC sadhill Digital Line Level 0 3rd May 2009 09:42 PM
DPA little bit dac modding (7350 dac, ym3623b receiver) ash_dac Digital Source 16 5th December 2007 07:09 PM
My DIY Digital Preamp/Source Selector w/ LCD & Remote Mr.Radar Chip Amps 3 8th February 2006 11:26 AM
Need to source TORX toslink receiver pixpop Digital Source 11 25th January 2006 01:13 AM
dac + digital filter + preamp JayV Digital Source 1 3rd July 2003 06:05 AM
