BIII with Broskie Unbalancer vs. EE Minimax Plus - My experience
Old 27th September 2013, 07:13 AM   #81
lordearl is offline lordearl  Australia
Doubt it - they're good quality. Low current passing through, so I really doubt you'd notice any difference.
I've changed the output caps to 10uF Obbligato MKP. Seem decent enough, and it allows me to use any power amp.
Old 15th October 2013, 05:35 AM   #82
kvardas is offline kvardas  United States
Well, in addition to the neohm 50R resistors in the I/V positions, I upgraded about 12 other resistors with a nice quality resistor. I also replaced the coupling caps with Duelund Cu PIO 1 uF coupling caps, which on purchased on sale from Parts Connexion.
I am very pleased with the end result.
Kris
Old 15th October 2013, 11:03 AM   #83
Wow! Beautiful job! What are those tubes - RCA clear tops?
I was playing around with my tubes recently and found a nice combination: Toshiba Hi-S 5963 as input tubes, and Raytheon 12AT7 output tubes. Very clinical sound! 300R MK132 cathode resistors.
Old 16th October 2013, 05:26 AM   #84
The tubes are 12AU7A. There made it the US and have a splotch of gray on the side. I am not sure if they are "cleartops". I got them for a buck a piece.
Kris
Old 21st October 2013, 06:42 PM   #85
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I bought a pcb from Broskie does anyone know what R18,R19 and C19 is for?
If they should be used?
Regards Åke
Old 22nd October 2013, 02:37 PM   #86
Ryssen's Avatar
I found out they are for bisaing the heaters .
Regards Åke
Old 25th January 2014, 03:30 PM   #87
zz1969 is offline zz1969  Russian Federation
What cap and resistors did you use at these slots, Ryssen?
Old 26th January 2014, 03:12 AM   #88
I found out. It depends. And this info is in Aikido manual.
Old 8th April 2014, 01:04 AM   #89
If anyone is still experimenting with the Unbalancer circuit, I thought I'd post a link to this thread as Ian/Ruffrecords has found a circuit error on the original Unbalancer PCB (the PCB which has the PSU included).
Grid resistors -> GND
Old 29th August 2014, 11:45 PM   #90
Luca72c is offline Luca72c
Hello everybody, i'm really excited reading this thread, i can't stand in my shoes waiting to build my B III + Unbalancer DAC!
But i'm 1/2 steps behind you and stuck deeply in finding out how to assemble an Unbalancer even starting from Glass-ware PCB...
Could someone please suggest me all R and C values for an I/V stage Unbalancer for a B IIIse DAC?
I would use JJ ECC802 input and EH 6CG7 output tubes and 2.2/3uF C3 (too much?); a Janus Shunt Regulator to power B+ and Heaters, set to 250/260V and 12.6V.
Just to state one of my problems, i can't figure out R12 correct value to achieve this as i'm not able to quantify the current flow on it. How can i calulate current flow in the Unbalancer?
Thanks to anybody will be so kind to help me!
BIII with Broskie Unbalancer vs. EE Minimax Plus - My experienceHide this!Advertise here!
Broskie "Unbalancer" - transformer specifications lordearl Tubes / Valves 9 28th August 2014 02:25 PM
Use Arduino to control BIII bigpandahk Twisted Pear 4 9th August 2012 08:52 AM
Minimax MW1125 to power NE5532 TheTree Power Supplies 2 22nd June 2012 04:08 AM
Broskie Unbalancer - manual query? lordearl Analog Line Level 0 17th March 2012 08:00 AM
pick tubes for tubecad unbalancer nightanole Tubes / Valves 0 3rd July 2011 01:59 PM
Copyright ©1999-2017 diyAudio
