PCM1704 sidebands around harmonics - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th July 2012, 05:27 PM   #1
q-rz is offline q-rz  Austria
Default PCM1704 sidebands around harmonics
Hi all DIYers!
First of all, sorry for my awful english...
Recently, I've built my first DAC with PCM1704's. The PSU consist of LM317's followed by simple shunt regulators. The input stage contains an FTDI USB chip, an Actel FPGA and a Tent Labs clock. The I/V converters are OPA627's, they will be changed to some discrete design at a later time. I'm planning to write an ASIO driver to be able to use it as an audio device with foobar or some other player. The only thing I currently have is a command-line application which sends out a wave file to the DAC. The sound is fine, but I'm sure there are million ways to make it better. I've measured an 1khz 24bit sine @ 44.1khz with my Terratec DMX 6Fire USB interface, and noticed that there are "sidebands" around the harmonics. Do you have any idea what could be the cause? I thought that jitter can only create sidebands around the fundamental frequency. Maybe I am totally wrong...
Peter
Old 17th July 2012, 05:45 PM   #2
kevinkr's Avatar
USB interface not asynchronous i.e. data clock frequency dependent on USB timing?
Anything using the Tenor TE7022L and other similar USB receiver ICs are not asynchronous even with custom drivers as far as I can tell. (I have a device that uses one of these chips)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 17th July 2012, 06:20 PM   #3
Hi Kevin,
Thanks for your reply. I use the FT232H from FTDI, which is not an audio device itself. It's basically nothing more just a small FIFO. The audio samples are "pulled" from this buffer by the FPGA, which is clocked with the Tent clock (11.2896mhz). Reading from and writing to the buffer are asynchronous processes.
Greetings,
Peter
Old 29th July 2012, 03:03 PM   #4
regal is offline regal  United States
Originally Posted by q-rz View Post
Hi Kevin,
Greetings,
Peter
Try realignment of the output of the FT232H with your clock and digital flipflops (even though you are clocking the FTDI with the tent clock it may be adding significant jitter since the chip itself runs at a much higher speed.)
Old 29th July 2012, 04:33 PM   #5
kevinkr's Avatar
I think this is good advice, and should be comparatively easy to try.. Perhaps reclock just ahead of the D/A converter IC? I'm thinking about what might be happening to the clock in the FPGA..
Where are and how harmonics generated? el156 Tubes / Valves 50 4th December 2010 03:32 AM
Cancelling Harmonics dsavitsk Tubes / Valves 20 10th July 2007 02:11 PM
odd harmonics? Pbassred Solid State 11 5th April 2007 01:17 PM
Speaker's harmonics - against what? anli Multi-Way 2 21st September 2006 07:58 PM
Phono harmonics scott wurcer Analogue Source 1 8th March 2004 10:09 AM
Copyright 1999-2017 diyAudio
