wm8804 jitter
wm8804 jitter
Old 9th August 2012, 09:59 AM   #21
pdcaceo is offline pdcaceo  Hong Kong
Are there any jitter improvment if WM8804 apply a low jitter clock ( for example Tentlab 3ps crystal)to them.
Or still keep 50ps performance without help.
Wilson
Old 9th August 2012, 05:37 PM   #22
twest820 is offline twest820
I think you probably meant ~62ps performance; see post 17 in this thread. Measured WM880x baseband phase noise is an order of magnitude higher than that of a typical crystal driver so diminishing returns most likely apply---it seems reasonable to assume Wolfson did a decent job on the driver so the PLL is probably dominant source of baseband jitter. If so, then there's negligible benefit for spending the extra dollar to go to from a crystal to a Fox XPresso XO---the improvement over something like a TXC 9C crystal would be somewhere around going from 126dB to 127dB DnR. In the rather unlikely case the DAC's good enough it matters. I haven't seen phase noise measurements of the Tent oscillators (though in fairness I haven't looked very hard) but the XPressos are competitive with Vectron XOs costing 20 times as much so they're probably competitive with the Tents as well.
wm8804 jitterHide this!Advertise here!
Some questions about the WM8804 tessier Digital Line Level 4 20th February 2011 05:52 PM
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
WM8804 Software Control fmak Digital Source 9 2nd January 2009 03:14 PM
Source for WM8804/5? error401 Digital Source 4 12th May 2008 03:43 PM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
