Python Open Room Correction (PORC)
Old 2nd November 2012, 02:48 AM   #51
Barleywater is offline Barleywater  United States
Food for filter thought.
If response contains a moderately high Q peak at low frequency, the time domain may go on for thousands of samples before dieing to below dynamic range of CD. A true correction filter will be the same length.
Example:
120Hz peak of 6dB with Q=5, with sampling rate be 48kHz looks like:
With time domain that runs on for more than 6k samples at 16bits and beyond 10k samples to get into noise floor of 24bit samples:
Getting great control down to 20Hz I find 32k-65k taps fills the bill, and for >60Hz 8k-16k taps.
Old 2nd April 2013, 04:27 AM   #52
timbarnes is offline timbarnes  United States
timbarnes's Avatar
Default Trying to get PORC working...
I have installed (I think) all the components of PORC, and it now runs, but I'm not seeing the results I expect.
Firstly, the graph that pops up only shows the uncorrected graph. Secondly, the .wav file that is created is not loadable by REW or the convolver in JRiver Media Center (I'm running the rather new Mac version).
Here's a snapshot of the graph produced, along with the results of running "play" on the file created.
JRiver shows a file status of "Not valid" when I load the output file. I've tried it in mono and in stereo (using sox to merge two copies of the original file to stereo).
Neither works.
Any suggestions?
Thanks,
Tim
Townshend Rock III, Hagerman Bugle 2, Naim CD5i, RPi Moode, MiniDSP, Elliot P101, IRS2092, Parham Pi Sevens & Pi Three
RC Preamp (in progress), Pass BA-3 and F4, DIY Silver cables, Open Baffle BOFU, DIY subwoofer, GainClone, o2 Headphone Amp
Old 2nd April 2013, 04:33 AM   #53
greenm01 is offline greenm01  United States
Just looking at the graph, you're definitely not getting the correct output. PM me, and send me your impulse responses, and I'll see if I get the same result on my end.
Old 2nd April 2013, 05:26 AM   #54
timbarnes's Avatar
Thanks - I just sent a link to the file via PM.
tim
Old 2nd April 2013, 11:53 AM   #55
Works on my end. I sent you a link to the filters in a PM. See below attached screen shot. I assume the stereo file you sent me was left/right channels (which I labeled the filenames), although they both look exactly the same to me.
Old 2nd April 2013, 04:15 PM   #56
timbarnes's Avatar
Thanks - it was originally a mono recording. I think I have it working too - there must have been something wrong with my installation. I went crazy with macports trying to reinstall lots of the packages, and now I'm seeing results.
If I want to reduce the amount of gain in the bass, I need to modify the house curve file - is that right? I suspect my (non-measurement) mic. is a bit weak in the bass. In any case, the results are causing clipping and boominess, so I need to cut back the low bass.
Thanks again,
Tim
Old 6th April 2013, 06:53 PM   #57
timbarnes's Avatar
Default Working with target files
I'm trying to modify my response so I don't get huge gain in the bass - my system is going into clipping. So I created a target response with attenuation in the bass. For some reason I'm not seeing the target response change as I'd expect. I've attached the graph from porc, and the contents of the target file.
My command line is as follows:
Code:
python porc.py -t target.txt -n 6144 FebImpulseOffice.wav OfImp2.wav
I would expect the output curve to somewhat follow the target...
Did I configure the target curve incorrectly?
Thanks for your help,
tim
File Type: txt target.txt (102 Bytes, 16 views)
Old 10th April 2013, 08:49 AM   #58
jlo is offline jlo  France
I tried same target with http://www.ohl.to/audio/downloads/align2.zip and no problem, result follows target. As I did some minor changes about target in porc.py, you may check this file.
By the way, I noticed that Mason added a new function about mixed phase compensation. Could we get some details ?
Thanks, Mason.
jl ohl
ohl about audio
Old 12th April 2013, 07:27 AM   #59
timbarnes's Avatar
Hmm. I tried Align2 and I can't get any output at all. I get a window of zero size and no files. I do see command windows go by, but they close before I can read the error message.
I guess there's something wrong with my installation, but I don't know how to work out what it is
tim
Old 12th April 2013, 03:58 PM   #60
Mixed-phase equalizers can correct the non-minimum-phase part of the Room Transfer Function (impulse response), in the time domain. The method I'm using is based on the paper ""Mixed Time-Frequency approach for Multipoint Room Response Equalization," by Alberto Carini, et al.
This white paper, published by Dirac Research, is a good, high-level, summary of mixed-phase equalization.
I'm the first to admit that PORC's installation process is tedious. I plan to make it a lot more user friendly: 1st by reducing some of the Python dependencies, and 2nd porting the code to C to create a stand-alone command line executable. Folks can use something like Align2 if they want a nice GUI on top (neither which I have time nor patience to create myself).
Python Open Room Correction (PORC)Hide this!Advertise here!
Introducing OpenDRC, Open Digital Room Correction engine minidsp miniDSP 20 20th January 2016 06:37 PM
How does the BeoLab5 room correction work? boris81 Subwoofers 0 6th February 2011 07:14 PM
Is a Room correction trial possible? brianuk PC Based 7 5th October 2009 08:29 PM
I need help with digital Room-correction Radian Multi-Way 1 7th February 2007 08:10 PM
Room correction systems herodote Digital Source 0 24th July 2006 11:56 AM
