DSP Xover project (part 2) - Page 85 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th April 2013, 11:31 AM   #841
chaparK is offline chaparK  Luxembourg
Originally Posted by Ryssen View Post
Do you have a schema of it,it would be easier to see.
There's really no need for schematics:
The 2 caps that are close to each other all have one pin that goes to the analogue volume chip, and the other pin is connected to the DAC output stage.
So you really want to bypass the output stages that include nice low-noise mini-melf resistors? Alright alright...
Najda DSP
Old 7th April 2013, 11:50 AM   #842
JLOP is offline JLOP  France
Originally Posted by chaparK View Post
I wouldn't worry too much about sample rate conversion.
I had a look a the application you have used so far, and suggest you just try rePhase (as recommended by a few forum
Hi Nick
On the first point, sorry to bother, but may you explain to the dumbs (;-) why we should not worry ? I think most of DSP do that resampling, but wont some samples get lost as 48 khz frequency is not a multiple of 44.1 ?
Thanks for the nice tutorial with rePhase ! What about phase correction itself ?
BR
Jean-Louis
Old 7th April 2013, 12:24 PM   #843
Julf is offline Julf  Europe
Originally Posted by JLOP View Post
wont some samples get lost as 48 khz frequency is not a multiple of 44.1?
No. No samples get lost - all samples get converted. The usual way of doing it is basically the equivalent of first upsampling by a factor of 160 and then downsampling by a factor of 147 (as the ratio between 48 and 44.1 is 160/147). Another way of thinking about it is to imagine the signal first being converted to analog at 44.1 kHz, and then resampled at 48 kHz. None of the samples are the same as the original, but the signal waveform is still the same.
Old 7th April 2013, 06:57 PM   #844
Attachment 341040
Thanks for the fast reply. Looks really promising then. I have a bunch of desoldered OPA627 that I would like to put in a DAC converter sometimes, fex
But decoupling caps? Are they not coupling caps in the signal path to block DC?
Actually the caps would probably be a better way to feed the signal, as you get a nice pad with a round hole in it. The IC socket is not a HQ socket, thus not that good for round pins.
As I have not seen the board and the layout especially , would it be possible to desolder the IC sockets without to much risk of damaging the routing?
I have quite good tools, but anything connected to a big heatsucking copper area is always difficult to desolder (like swollen filter caps on PC motherboards, they are a pain in the donkey to desolder)
Sorry for all the questions, but what post DAC filter topology do you use ? Sallen Key or MFB? I used MFB in my post-DCX2496 differential-single-ended filter to prevent oversampling noise feedthrough @ MHz.
listen! Can you hear that ...
Old 8th April 2013, 02:04 AM   #845
You're right, I meant coupling capacitors.
Do you realize I've put the opamps on sockets so that you don't need to desolder anything - and now you come and ask me about desoldering the sockets themselves?
Najda DSP
Old 8th April 2013, 03:31 AM   #846
Mr. Nick, Sir, thank you so much for the tutorial on building FIR filters. Sorry about the late reply. I had to get out, and listen to live music this weekend. 2 weeks ago I thought fir filters were something that went on the shower drain. Now I am listening to music on my new toy. It has replaced an elderly Marchand XM9 in my pile. One question, if I use either channel 4 or 5, I cannot get the output graph to sum to a flat line in Najda Under Control. It is an either or thing. Should I ignore it as a glitch? I am using channels 1, 2, 3, 5, 6, and 7. And it is working perfectly. Sounds pretty good to my antique ears! Thanks again for all your help. Very cool toy!
No I can't f***ing hear it so turn it up real LOUD!
Old 8th April 2013, 03:45 AM   #847
Oh yeah, that miniature remote from China off Ebay for cheap, sucked the life out of the battery just sitting there. Maybe not a great deal.
Old 8th April 2013, 06:04 AM   #848
I said sorry
Old 8th April 2013, 10:33 AM   #849
I suggest you check the rePhase thread:
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
That's cool Mr. Mark! If you want to send me your setup files on my email, I can check what's the issue with channels 4 or 5 you mentioned above.
Maybe it just needs a fresh battery
Najda DSP
Old 8th April 2013, 07:46 PM   #850
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Is there an error in the manual regarding the +5v line?On the pcb it says one thing,and in the manual another.
Regards Åke
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
Copyright ©1999-2017 diyAudio
