| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#631 |
Cos Nick and Paal said so
![]() A very quick search for linear PSU's throws up even less options for me - no all one options came up - Am I looking the wrong place? - Farnell, RS, Ebay... My switching PSU arrived and it's tiny... I'll dummy load it and measure it + current in. I fixed the Najda board down to a bread broad yesterday evening and got prepared for the PSU. Got a suitable metal box for the PSU. This evening I will wire up the push-to-make key pad. |
#632 | ||
We can expand this by going FFT. How many coefs exactly I don't know, I would need to look at the details but don't expect 16k coefs per channel. Fact is we're going to hit memory limits: ram memory for computing the filter and even eeprom for storing coefficients. I'm surprised with the number of coefs that you are throwing. I'm convinced that 16k coefs at 48kHz sampling rate is way overkill and that there are more elegant solutions to achieve similar result with shorter filters. We'll find out how. Snitching is not nice ![]() Quote:
We don't really know what they mean when they say 'min. load'. I guess the PSU is not going to blow, what do you think? Maybe it's just that the other specs are just outside their limits in the datasheet, but still OK for normal use. (maybe not) |
#633 | |
Nick, you better use 8x decimation
![]() Quote:
have a look here: the ACTIVE CROSSOVER DESIGNER (ACD) tools thread best, Paal |
#634 | |
Also I received today from Mouser some nice That 1200 and That 1606 drivers that I will use later to expand the Najda board with symetrical input-outputs JC |
#635 | |
Hi Jlop, Thank you for your comments. I have the following response. Regarding PC noise. Contemporary PCs have excellent SNR. I have measured and compiled the results in http://www.bodziosoftware.com.au/Computers_SNR.pdf paper. You will find, that PCs are equal or better than some of the CD players. Regarding PC burden. PC is actually used as an audio server and the same PC runs UE4. You can even run “full digital” solution described in http://www.bodziosoftware.com.au/Ult...in%20SPDIF.pdf paper. This is really uneatable combination for convenience and the cost of music. The PC solution is simply unmatched for user friendliness, audio server function, and multi-channel HT application. You may have noticed, that iTunes has been offering ".m4a" and ".m4p files now, instead of ".mp3" files. The ".m4a" files are much less compressed, thus offering better sound quality. I stopped buying CDs about a year ago. I buy my music exclusively as single files of very selectively chosen songs, and this necessitates a PC for a music server. But this approach also offers huge cost savings in purchasing the music - this is the way to do it. The same PC runs the UE4 - so it all matches for me to perfection. Regarding sound cards. In it’s basic configuration, you do not need any sound cards – you can use 2in/8out motherboard audio codec, such as ALC889 or ALC898. However, sound cards (delta1010LT for $220) expand capabilities of the UE. With two sound cards, you can have 16in/16out signal routing capabilities – example in http://www.bodziosoftware.com.au/Signal_Routing.JPG paper. So, you can have 8 stereo sources, or 2 HT +2stereo sources connected to the UE4 system, and freely switch between inputs with single keyboard button press. Best Regards, Bohdan |
#636 |
Hi Bohdan
Thank you for your fast answer and very interesting attached documents, especially about PC electrical noise. These infomation is unfortunately not often available to audio PC builders. I was in fact speaking about acoustic noise from fans, which is difficult and costly to get rid of for powerful platforms.Same PC may not be used as server for many reasons including noise of HDD, backup disks, screens, etc Let me stress that I did not intend to dismiss your software solution, which seems very comprehensive to me as far as I understand. I just wanted to stress that a on a one board DSP you (may) have to restrain your ambitions compared to a powerfull PC based solution. Both have a public of course, depending on the requirements. There are quite nice soundcard, but, as far as I know and I am definetly not a great specialist, their SQ cannot compete with some very good DACs, especially for output stages, so I have a feeling that going digital out of the PC and have DA conversion in a specific HW might be better. Just a thought. Please feel free to comment ! BR jean-Louis |
#637 |
@jlop and bohdan1232000, interessting discussion, but isn't it off topic for this thread? I'd be keen to read it in another though. BR
#638 |
You are right , just leaving some Time to the beta testers (;-)
#639 | |
is choosing a less facetious title...
thats a myth, there are some truly superb soundcards. apogee, the metric Halo LIO-8 and ULN-8 (both have external DC supply inputs and a pretty impressive DSP onboard) Lynx make some excellent hardware too. much more expensive than this board here, but both DSP and analogue are considerably more powerful.
its possible to construct a dedicated multichannel dac that outperforms them, but it would require considerable effort and funds and their drivers are rock solid. External wordclock high quality preamps. Quote:
#640 |
Shaun has reported a bug that prevents from loading IIR files into the processor. This happens with files that involve lots of filters.
I have identified the issue and I have a fix for that. We'll do some testing then I'll post the new release asap. Sorry for the inconvenience. Thanks Shaun for reporting the bug! |
| DSP Xover project | chaparK | Digital Line Level | 141 | 3rd July 2011 10:16 AM |
| Help Please for simple active Xover project | dcathro | Analog Line Level | 4 | 9th September 2010 05:47 AM |
| Violet DSP Evolution - an Open Baffle Project | cuibono | Multi-Way | 211 | 18th May 2010 02:26 AM |
| Software digital DSP ... Xover/filters/EQ ?? | JinMTVT | Digital Source | 2 | 8th October 2004 06:02 AM |
| DSP card & proper xover for heathkit 859A speaker cabinet | x. onasis | Multi-Way | 6 | 22nd April 2003 07:39 PM |
