DSP Xover project (part 2) - Page 200 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd March 2014, 03:37 PM   #1991
chaparK is offline chaparK  Luxembourg
Hey a first black one out there!
(I first wondered: How did Abel manage that on the LCD? )
Najda DSP
Old 23rd March 2014, 06:13 PM   #1992
Originally Posted by WhiteBull View Post
Hello, is this display an oled? If so, where did you get it?
Best regards
Sigi
Old 23rd March 2014, 08:11 PM   #1993
Hi Sigi,
it's a cheap 4€ LCD from here:
LCD Display 480x240 Graphical 3 in one Blue White RED Artikel im zyscom Shop bei eBay!
Abel
Old 25th March 2014, 12:18 PM   #1994
Hi Nick,
the info in the following link might be useful to get some OLEDs working. Have a look if you've got a moment … especially post 4&5 in the link ...
Raspberry Pi • View topic - OLED 16x2 HD44780 woes
Abel
Old 25th March 2014, 08:00 PM   #1995
i suspect "real" hd44780 compliant vfds are also picky about startup sequence and timing (i.e need strict compliance)
Old 25th March 2014, 08:05 PM   #1996
Shaun is offline Shaun  South Africa
Shaun's Avatar
Nice find, Abel! This is the optimum solution: the same piece of code for both types of display.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 26th March 2014, 10:49 AM   #1997
Thanks Abel, I'll have an extensive look at this as soon as I can.
As far as I can tell, the so-called drop-in replacements for HD44780 are actually not directly compatible.
I've tested a OLED display with a Winstar driver: nothing at all on the display. I suspected the display was DOA, I'll have another look.
The VFD mentioned above displays garbage. The good thing is that the garbage is correlated to what I'm doing with the Najda - i.e. the garbage changes each time I press a button. Better than nothing huh?
I have good hope to make all these displays compatible in a near future - stay tuned
Najda DSP
Old 26th March 2014, 06:44 PM   #1998
paalj is offline paalj  Norway
Originally Posted by chaparK View Post
Hi Paal,
The number of available taps will depend on your sampling frequency and on the use you make of the IIR section. If you give me this info along with the DSPs load, then I can let you know how many approximately.
Nick
Hi Nick,
@ 96kHz sampling freq, the load is 44% and there are 10 IIR's/ch.
best,
Paal
Old 27th March 2014, 04:56 AM   #1999
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
Any of you fine lads tried any forms of discrete opamps on the najda dsp board?
Wondering if worthwhile!
Old 27th March 2014, 09:55 AM   #2000
Hi, take a look at post 1792!
Sigi
DSP Xover project chaparK Digital Line Level 141 3rd July 2011 10:16 AM
Help Please for simple active Xover project dcathro Analog Line Level 4 9th September 2010 05:47 AM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Software digital DSP ... Xover/filters/EQ ?? JinMTVT Digital Source 2 8th October 2004 06:02 AM
DSP card & proper xover for heathkit 859A speaker cabinet x. onasis Multi-Way 6 22nd April 2003 07:39 PM
Copyright 1999-2017 diyAudio
